I am installing a new Whirlpool Double wall oven and a separate cooktop range in a new remodeled kitchen (converted the carport into huge new kitchen). When I installed the wiring, I thought the oven was going to be a 50 amp (based on research before the oven was purchased) and so I ran 6/3 wire for the oven and 8/3 wire for the cooktop. Now that I have the appliances purchased and in the kitchen ready to be connected, I can see that both of them are just 40amp. I have separate 40amp breakers in the box for them. Is there any issue with the 6/3 wire being used on the 40amp circuit for the double oven?
Asked
Active
Viewed 85 times
1Within reason larger wire are always good. It is they just cost more(usually) and can be harder to work with. – crip659 Aug 07 '23 at 16:30
You can use the 6/3 with a 40 amp breaker, just fine.
The breaker protects the wire. Wire can be oversized to the protection of the breaker, but not undersized.
You are fine.
RMDman
- 25,114
- 2
- 22
- 58
Wouldn't hurt to mark the wire as 6/3 too, just so it's easy for some future person who might need a 50A circuit to know they can do it simply by swapping the breaker. – Huesmann Aug 08 '23 at 14:05
