Newly Installed ground floor Shower room has sewer smell.Flushing toilet causes gurgling & vacuum in shower drain
Asked
Active
Viewed 944 times
1Welcome to [diy.se]. When you take the [tour] you'll note that this is a _Question_ and Answer site, so it would be good to [edit] your question to actually ask a question. Also, we're going to need a lot more information about your installation - some pictures and details of the plumbing (for instance, is the plumbing properly vented?) will be really useful to help us help you. – FreeMan Aug 09 '23 at 13:18
Get your plumber back to make it right. Assuming a plumber installed it. – Ecnerwal Aug 09 '23 at 14:20
Sounds like there's a missing vent or a clogged vent between the toilet and the shower. Flushing the toilet sucks the water out of the shower trap and allows sewer gas to enter through the shower. If a contractor did the job, get them back to fix it. If it was a DIY job, check the venting.
JACK
- 78,739
- 18
- 72
- 188
1There is a vent& it is not clogged. I wonder was the drain laid with the correct gradient? – Margaret Aug 09 '23 at 14:46
3Do you know the exact location of the vent? Were traps installed in the shower? Won't knnow about the correct gradient unless you rip up some stuff. – JACK Aug 09 '23 at 15:23
The plumber that did the work is coming tomorrow. I hope that there is a solution other than digging up the floor The distance between the shower & the toilet outlet pipe is 1.4m (59") – Margaret Aug 10 '23 at 18:22
