This is a UK house build around 1900. The ground floor room had no flooring or carpet, just the subfloor was exposed. We decided to decorate the room with wood laminate flooring with an underlay and new paint. Few days later we observed signs of damp near the bottom of the walls, this has only increased over the last 1 year.
Why could this be happening and how can this be stopped? It has only appeared after we put in the laminate flooring, we thought it might go away after a while once the building gets use to the changes (flooring and underlay with new paint) but it has not.
EDIT:
This is on ground floor. The damp appears on only internal walls. The underlay is a Silver Underlay for Laminate Flooring which came as a rolled up mat. Thus, it is clear that the underlay traps moisture. There is no dry wall, these are more than 100 years old masonry walls. Yes, there is plaster on the walls.
quantum231
  • 551
    What was the subfloor material? What is under that (e.g. concrete slab)? What material are the walls (lathe & plaster, drywall, etc.). Are they interior or exterior walls? Is this above or below grade? – blarg Aug 14 '23 at 23:06
  • What do you mean by grade? – quantum231 Aug 14 '23 at 23:20
    Grade = ground level. – blarg Aug 14 '23 at 23:24
  • Perhaps the underlay (assuming it's waterproof) forced all the moisture coming up through the slab to the edges of the room, and the only way out from there is up through the walls. – Huesmann Aug 15 '23 at 12:23
  • ok, that is what could be happening as well, but what is the solution to this problem? – quantum231 Aug 15 '23 at 19:37
0 Answers0
