I am not a tile guy by trade but I have set hundreds and hundreds if not thousands of square feet of tile. What I see there is typical if it is only here and there.
When spreading thinset, the areas cannot be too large or the surface starts to dry enough to loose it bond with the tile, so the areas need to be kept small, also to be able to reach tile laid already to get all the joints looking proper. When troweling thinset, it is difficult to get the thinset well into the corners without getting the thinset onto the tile, which can get into the joints of the already laid tile because of that. Its a real pain to keep clean when trying to get thinset to the corners as it is. I spread enough thinset to cover approx. a 2X2 ft area. So if the tile guy there does close to the same thing you may see a void about every 2 ft apart, and only at the corners of the grid he used to place thinset by.
When the grout is spread, it will be forced into the joints to fill the remaining voids left by the thinset that did not make it into the corners.
FWIW, tile setters do not like ungrouted floors walked on, because, and this is what I have been told many years ago, is that the corners of the tile are the weakest place in the floor and the potential to crack the corners is high, until the grout is set.
