I am looking to build a paver walkway along the side of my house. I would like to build it with an open graded base as that seems to be the preferred approach nowadays. With that said, I have been to 4 masonry/landscaping supply centers in my area (Long Island to be specific) and the only open graded aggregate offered is a 3/4 inch washed bluestone. From what I gather, this stone is primarily used as a decorative top layer material. Would it still work as a paver base? It is a sandstone. Does that make a big difference? It seems limestone is more common to use for a paver base. Is that correct?
Thank you for your help.
P.S. Each supplier recommended I instead use their 3/4 inch minus RCA.
    You probably can use it as a base, but whenever the word decorative is added, the price tends to go up. For a hidden base you want the cheapest stuff that does the job. The suppliers know what works good in your location. – crip659 Aug 27 '23 at 23:29
  • `limestone` not in our part of the world. Its always fine metal and sand – Rohit Gupta Aug 27 '23 at 23:56
    You might want to expand your search beyond landscaping supply houses. See if you have a construction aggregate supplier nearby, and see if they have crusher run, or whatever NY DOT uses for road base. – Huesmann Aug 28 '23 at 12:15
  • @Huesmann, I found additional stone suppliers in the area by googling “construction aggregate supplier”. They confirmed bluestone is an appropriate stone for building an open grade base. Thank you so much. – teachmehow1977 Aug 29 '23 at 23:12
    Note, for this purpose *bluestone* isn't specifically required. The important part is that the material is well-graded, i.e. including a good proportion of all gradations, not just big pieces or small pieces. Some places sell recycled concrete, which is basically pulverized concrete (from construction demolition), which is good enough for a patio or driveway. – Huesmann Aug 30 '23 at 12:20
  • Long Island, NY, USA is a _loooong_ way from your part of the world, @RohitGupta. Frankly, it's hard to imagine too many places that are further away from NZ! ;) – FreeMan Sep 27 '23 at 16:22
The only thing that should matter is if it's crushed stone or gravel. Crushed stone is preferred for drainage applications. When you tamp it, it is supposed to interlock and provide a more stable base than gravel of the same size.
If the bluestone you are being offered is decorative, it usually is more expensive. For example, where I live regular crushed stone is about $25 a ton vs $50 per ton for decorative crushed stone. If that's all you can find, it will work the same. But depending on how much you need, it might be worth a trip to a quarry and to ask if they deliver regular 3/4 crushed.
Also, for all I know, open base is not just 3/4 stone, but 3/4 stone with 1/4 stone on top. The whole point is to use a material that easy to move around, ie will give a little bit but will not continue compacting over the years.
Cheery
  • 4,155
  • @Cherry, thank you for your input. I found additional suppliers in my area who also confirmed bluestone will work. The prices quoted are around $65 per yard. I think though that the price is more a reflection of my area than anything else. Thank you again for your input. – teachmehow1977 Aug 30 '23 at 04:45
