During thunderstorm our home had an instant power loss. Then one of the hvac's outside machines started roaring sound that was audible from inside of house, which I have rarely heard even when hvac is set to work hard. After some time and also some operations on the hvac's in-room panels, the sound stopped.
Question: What could cause such a roar, esp. when the hvac was NOT set to "work hard" (e.g. extreme target temperature was not set)?
Order of events:
- (Added on 20230831) The a/c in question was actively cooling the room (I verified just now looking at the smart system's log).
- In the midst of thunderstorm, whole house instantly lost a power, it came back on within less than a second. I immediately started hearing roaring sound from one of the hvac's outside machine (I later identified only one of them was making the noise, by turning off hvacs one by one).
- (Added on 20230831) During the roar, the a/c was NOT cooling the room (at least that's what my smart system (Home Assistant) recognized) despite the target temperature was lower than the measurement right before this moment so it should've continued to cool..
- Maybe 10 minutes or so passed, I turned off the power of hvac systems (via smartphone app, one by one as mentioned earlier). Roaring sound stopped when turning off one of them.
- I turned hvac systems back on (no more roar heard).
- I went to one of the panels of thermostat, pressed some buttons manually. Commands didn't seem to get activated by that, so I wiggled the panel a bit too (this panel is not firmly attached to the wall. I don't know if this is related at all).
