None of the outlets are grounded and two of them are omitting a strong plastic/ electrical smell. We rent our house but dont have a lease. Our landlord threatened to "find new renters" if we pursued this issue. Its a fire hazard but we cannot afford to move.
How do we shut down just these two outlets until we can leave?
Maizy
    The proper way is to flip the breaker or pull the fuse for that circuit. The reality is that an old house with ungrounded receptacles may have a dozen different receptacles, overhead lights, etc. all on one circuit, so turning off a single circuit might leave you in the dark. The proper way to fix it is to replace the receptacles, but that gets into the "can't work on a rental property" yourself problem - basically if something goes wrong the landlord will blame you even though you may have actually improved the situation. – manassehkatz-Moving 2 Codidact Sep 26 '23 at 02:49
    Wow, an "electrical smell" could be arcing. I mean, this is how house fires start. I hope your deadbeat landlord provided working smoke alarms; in my area it is the law. I would report that dude and start looking for a new place if possible. – Jimmy Fix-it Sep 26 '23 at 02:59
    I would suggest you may not be able to afford _not_ to move. – keshlam Sep 26 '23 at 03:14
  • Get a smoke alarm to save your self and let it burn down – asinine Sep 26 '23 at 03:23
    This wanders into legal territory, so I’d like to suggest you explore your renter’s rights, either locally (ie, legal aid) or the legal stack here. The lack of a written lease doesn’t mean you have zero rights, but it is generally the case that landlords can make your life miserable if they put their mind to it. – Aloysius Defenestrate Sep 26 '23 at 13:56
0 Answers0
