13
QUESTION: Just, why ?
I was exploring a local swap meet and found this. For the life of me I cannot figure out why one would need an adjustable spanner at each end.
I mean it's ADJUSTABLE and having two on the same handle means you can't tighten a nut and bolt at the same time.
Criggie
  • 10,046
  • Noted - the quality of the surface was quite rough and looked like sandcasting - maybe this was a shop-made copy , an exercise in casting and machining ? – Criggie Sep 27 '23 at 00:40
    Apparently Crescent Tool Company started in 1907, and invented the crescent wrench. Maybe an old tool? – Jon Custer Sep 27 '23 at 00:44
    See https://www.garagejournal.com/forum/threads/crescent-double-ended-wrench-history.161398/ for more info. Made for many years, since the 1910’s and stopped sometime in the 60’s apparently. – Jon Custer Sep 27 '23 at 02:07
    @keshlam, I like your idea. It would make a better answer than comment. – isherwood Sep 27 '23 at 14:02
    It's the gift for the dad who has everything. – FreeMan Sep 27 '23 at 15:21
    @Criggie, I've seen some of my dad's tools that look like that, yet were store bought. Not everything was chromium plated back then, and older steel tools tended to pit like that in wet climates or when used in wet applications. The knurling on the adjustment is plenty distinct, which wouldn't necessarily be the case in sand casting. And if it was cast as a single piece, the jaws wouldn't have the seam between them and the slide body as it does. Check out my answer below for more info, if you're interested. – computercarguy Sep 27 '23 at 21:13
  • @computercarguy my takeaway from all this discussion is, I shoulda bought it ! – Criggie Sep 28 '23 at 03:04
    Maybe if you're lucky, everyone else who sees it will wonder the same thing until the next swap meet :D – Journeyman Geek Sep 28 '23 at 03:46
    @Criggie, it's definitely an interesting piece to have for display, but I'm not sure I'd want to have it in my toolbox, even if it was new. I'm still not convinced as to how useful it is anymore, even without the rust. – computercarguy Sep 28 '23 at 16:48
    One end is metric, the other end is standard. – Steve Wellens Sep 28 '23 at 16:55
    Whoever deleted Harper's comment: BOOOOOOO. fheckin lock the comments then. – Mazura Sep 29 '23 at 03:06
    @SteveWellens Nearly lost my coffee there! :) – Graham Sep 30 '23 at 08:44
6 Answers6
16
According to the thread on the Garage Journal web site, these type of wrenches featured 2 different Jaw sizes and were also thinner than normal so as to be more easily used in tight spaces.
This is the ad for the version made by Crestoloy (a different ad shows a model made by Diamond.) enter image description here
Additional information specifically on the Crescent brand is available here: https://aplanelife.us/blogs/f/a-mystery-with-two-ends
Earl
  • 424
I used to have one of those (Crescent brand). The jaws at either end had significantly different capacities. One tool instead of two. As someone who frequently had to lug a heavy tool bucket around, makes perfect sense to me.
kreemoweet
  • 2,538
    What does "significant" actually mean here? The big one can be adjusted to the smaller one's sizes, so the only times I can think of that this doesn't work are due to working space limitation, but at that point, I wouldn't even be using an adjustable wrench in a tight space to begin with because there are better tools for that. – Nelson Sep 27 '23 at 03:55
    @Nelson No, they are not the same, even if set to the same width - try it and see. The whole point of these adjustable wrenches is to avoid having to carry around complete sets of single-size tools, which admittedly are superior for some purposes. But Good Enough is exactly that. – kreemoweet Sep 27 '23 at 21:29
    I'd still carry my tiny one, the big one that can go over 1/2 NPT unions, *and* that thing to back up either one, instead of the middle sized one I leave in the truck for that. Want.... – Mazura Sep 28 '23 at 01:03
  • @Mazura I think that could actually be its use case - as the 2nd (holding still) spanner for but big fittings and smaller ones in tight spaces. IMO it would be much more useful if the smaller end were smaller still - a lighter build and perhaps thinner jaws for the same opening – Chris H Sep 28 '23 at 08:00
    @kreemoweet: you're the one posting an answer for the benefit of other people that are curious. It would be better if you could put into words what some of the differences are, since not everyone will even have multiple adjustable wrenches they could go grab, and reading two sentences to guide their thinking in the right direction would still be faster. (This is on HNQ now, so the audience includes people who don't use wrenches regularly.) This is what Nelson was trying to encourage. – Peter Cordes Sep 29 '23 at 01:13
  • My guesses about what's significant are that the small end is thinner, and the jaw pieces stick out less to the sides, letting it get around a nut when other things are right next to it. Are there other important differences? Perhaps the amount of play in the threads, letting the small end get a tighter grip on a small nut? – Peter Cordes Sep 29 '23 at 01:15
If you are working on something with a LOT of fasteners, of two different sizes, you wouldn't want to be continuously adjusting a single wrench back and forth. This lets you have both settings available.
Or, if you were going to carry both wrench sizes in your toolkit anyway (to have the full size range but also fit in tighter spaces), this might be a cheaper (and lighter weight?) alternative.
Or it may just have been "You can't decide? Have we got a tool for you..."
But I agree it doesn't look especially practical, and unless there was a very specific market (preassembled toolkits? military procurement?) I'd be surprised if it did well in the market.
I'd suggest trying a image search on the web and see if there's a write-up somewhere. Tried a quick search myself and did find hits but haven't dug into whether any of them have the history.
keshlam
  • 27,539
  • 46
  • 94
    I've used plenty of adjustable wrenches, Crescent brand and others, and even for the same size bolt/net (even the same exact bolt/nut), continuously adjusting the wrench is necessary to slide on and fit correctly, as well as just to stay on. Personally, I only use these types of wrenches as a last resort, or if I forget just how lousy they work and end up having to get the correct socket or combination wrench after damaging the faster and/or my knuckles. ;-) – computercarguy Sep 27 '23 at 21:35
    There's a technique to sliding a thumb to tighten them as you put them in place... I find that good adjustable wrenches work well enough for many tasks, and weigh a lot less than a full inch-plus-metric kit. Compromises, as always. (Then again I've never been a motorhead, so I don't have a rolling cart full o' tools.) – keshlam Sep 28 '23 at 04:13
  • I know the thumb technique well, yet the way the wrench slides never really makes for smooth operation. The backlash always seems to lockup the screw. Maybe mine are just old and/or cheap, but they just don't stay adjusted. I have to keep my thumb on the screw, which limits my grip and power. I wish I had rolling carts for my tools, then I'd only need 2 of the massive ones, instead of dozens of small toolboxes with dozens more bags and just plain loose power tools. Lol. I have way too many tools... – computercarguy Sep 28 '23 at 16:54
  • Same answer in my words: You can set one end to one size and the other end to another size and then easily switch back and forth between those two sizes **without having to make an adjustment** to either worm screw. Useful if your work has nuts of two different sizes. – Wyck Sep 29 '23 at 19:42
The point is the same as the point of owning 2 differently sized Crescent wrenches.
You can choose to only own one large wrench and use it for smaller fasteners, but some people will prefer to have choices. This tool seems silly to me, but I understand why someone might want one.
Tiger Guy
  • 1,564
  • I think this hits on the point. If you are going to own multiple sized crescent wrenches why not have the ability to purchase two in a single tool instead of having to buy multiple ones. – Joe W Sep 27 '23 at 16:38
    @JoeW - well, with two different ones you can hold both the bolt and the nut... – Jon Custer Sep 27 '23 at 18:39
  • @JonCuster But you wouldn't really need two different sizes for that. – Joe W Sep 27 '23 at 19:00
    @JoeW - true, but I don't have two of one size either. The point is that sometimes you need two wrenches, so that double-wrench won't do you any good if it is the only one. – Jon Custer Sep 27 '23 at 19:06
  • @JonCuster True, and you also likely have more then two wrenches as well meaning even if they all where double sided you would still have enough to hold both the bolt and nut. – Joe W Sep 27 '23 at 19:12
    The point is that you usually need two, no matter what. This is the *third* one that keeps you [from having to carry](https://diy.stackexchange.com/a/282674/23295) *four* (two big, two little) instead of a singular mid sized one that isn't "good enough" half the time and leads to either it's schlock or I'm going shopping. – Mazura Sep 28 '23 at 01:11
  • @JoeW bet me! Having just done a whole lot of new work plumbing in my basement, there were _plenty_ of occasions where I needed to screw two different fittings together and the flats on each fitting were different sizes. I get needing two different size tools, and I get the convenience of this two-tools-in-one device, but there were _plenty_ of times I used two different sized tools to make one connection! – FreeMan Sep 28 '23 at 11:53
  • @FreeMan I don't know anyone who owned only 1 or 2 crescent wrenches is was always more then that and even if they cut the number in half by making them all double sided it still would have been more then 2. – Joe W Sep 28 '23 at 12:37
If you look closely, you'll see in the 2nd picture on the left size, it says "8-10 in", meaning it has the wrench ends of an 8" wrench and a 10" wrench. This means that one side is slightly larger than the other.
Here's an eBay listing that has slightly better pictures of what I think is the same model of wrench.
https://www.ebay.com/itm/256231330667?hash=item3ba893d36b:g:qpkAAOSwJ5BlEIuv
To me, the slight difference in the head size without the added length of a 10" wrench doesn't make the tool that much more useful than if they simply had the 10" head with a shorter handle.
However, a dual headed adjustable wrench seems to be somewhat common(?) for older tool sets, as I found a variety of different versions.
https://www.ebay.com/itm/335022055565?hash=item4e00dee08d:g:YAcAAOSwEXFk-8e0
https://www.ebay.com/itm/225708806765?hash=item348d4b126d:g:uhYAAOSwTXpkzRLN
https://www.ebay.com/itm/155730057316?hash=item24423c1864:g:~TEAAOSwlohk45Vb
http://alloy-artifacts.org/diamond-calk-horseshoe.html#intro
And a forum talking about different varieties, as well as what they are and why they were made/used.
https://www.garagejournal.com/forum/threads/double-end-adjustable-wrenches.359472/
I'm just guessing here, but this may have made more sense when steel and/or tools were relatively more expensive than they are today. There's also a semi-common modern desire to "own all the things/tools", while older generations bought only what they needed, and only if something couldn't be repurposed or wrangled into working.
Also, some work pants used to have a long, thin pocket or denim loop that could basically store exactly one wrench down the side of the leg (before cargo pants/shorts). Overalls and coveralls also tend to have these pockets and loops. If you had to choose what wrench you wanted to put in the pocket or loop, the double headed wrench might fit the need. Growing up on the farm, we often kept a hammer in the loop, but not everything is a nail.
I found a modern version that has both the loop and the pocket (2 pockets in this case).
https://www.lee.com/shop/carpenter-jean-original-stone-30-34-2887910%3A30%3A34.html
computercarguy
  • 1,770
    a double headed wrench wouldn't easily fit through the loop. – Jasen Sep 28 '23 at 01:03
    Not everything is a nail, but with this wrench in your hammer hanger, you don't need a hammer! ;) – FreeMan Sep 28 '23 at 12:07
  • 10" or even 8" seems like a heck of a jaw opening to me. Not many nuts that size - and if there were, they'd need a darn sight longer handle on the tool. – Tim Sep 30 '23 at 12:42
  • @Tim, the 8" and 10" are referencing the length of the tool, not the size of the jaws, so it's an unfortunate misnomer. The actual size of the jaw openings vary from brand to brand, but 8" models are usually 1-1/8"-1-1/4" wide max and 10" models are around 1-1/4" to 1-1/2" wide max, from what I can find in online descriptions. This is why a tool with both an 8" and 10" adjustable head doesn't make much sense, since their max capacities are so similar. The 8" head is slightly slimmer to fit into narrower places, but again, that's not much difference. – computercarguy Oct 02 '23 at 18:25
I wanted to share my thoughts on this, which may or may not be right.
In addition to what the others have given, I see 2-3 benefits:
  1. the 2 ends may be suitable to right-handed & left-handed users & situations: giving the better grip in one orientation for one group of users & one set of situations. [ In case it is not obvious to the downvoter(s) , the 2 heads are not rotational-symmetric , they are mirror-symmetric , which might make the tool suitable to either hand & either orientation ]
  2. when the threading/alignment/tightness goes bad on one end, the whole tool need not be discarded, because the other end might still be good, which improves the lifetime of the tool.
  3. unintentional benefit: the thicker end gives a better control/handle/grip when holding at maximum distance.
This is just my guess-work.
Prem
  • 109
