Why is sump pit built to bring exterior water into basement only do to be pumped away? The basement is dry except where the pit creates a penetration. Why invite exterior water into the basement?
The sump pump could empty a pit that collected water which found its way into the basement by misfortune.
Why not keep the basement shell waterproof like a boat and only pump if there is a leak?
mshore
    It's not *inviting* water into the basement. That water is there, and there is nothing you can do about it except try to remove it. – Huesmann Oct 09 '23 at 11:51
    You invite water into your basement by putting the basement into the ground. – FreeMan Oct 10 '23 at 13:37
    A basement is basically a concrete boat. The ground was water in it. The only reason your concrete boat still floats is because the dirt provides resistance (although I'm sure on much larger time scales your concrete boat will still sink). Don't let the dry surface of the ground fool you. There is water all around your basement. The basement creates a cavity that gravity + water wants to fill. And water wins. Every time. You can't keep water out, just give it a place to go. – Greg Burghardt Oct 10 '23 at 16:47
    And a sump pump is basically a bilge pump for your house. That gives you the right perspective on your basement. – Greg Burghardt Oct 10 '23 at 16:54
  • Isn't the real Question whether it's better to pump out a sump, or to install a drain into a larger space? The cost of digging is one aspect; the availability of free space another and doubtless there are more considerations, but how is the choice solely 'to pump or not to pump'? – Robbie Goodwin Oct 10 '23 at 18:17
6 Answers6
20
Getting the basement to be a waterproof shell like a boat may be possible, but maintaining that waterproofness is very likely not possible over time. Ground shifts, concrete and mortar dry out, foundations crack, and water can come in. Other ground shifting can occur elsewhere and make a dry piece of land wetter from underground. Hurricanes and heavy thunderstorms happen, and seem to be happening more. The chances that a dry basement may get wet from water outside aren't down to 0.
Additionally, if a place exists for water to get close to the basement and get pumped away before the water gets into the basement, then that's good planning. Make an easy place for the enemy to approach and it'll be easier to stop the enemy.
It's a matter of risk assessment. Strange things happen when one is not looking. If one plans for as many strange things as possible, then one won't be as taken aback when strange comes calling.
Triplefault
  • 6,374
    Depends on where you live. I grew up in the Intermountain West (Southern Idaho). Water table was 1500 feet down at best. Everybody had a basement, nobody had a sump pit/pump. Wet basements just aren't an issue there. I now live in the Midwest. This answer is 100% guaranteed correct for here. – FreeMan Oct 09 '23 at 13:34
    Another problem with waterproof shells is that sometimes they can detatch from the surrounding ground and float. – Peter Green Oct 10 '23 at 04:50
    @PeterGreen is that a real thing? I've read about it many times, IE overzealous waterproofing can cause house-planet detachment. But I've never heard of it actually happening or of building codes or engineering standards requiring buoyancy calculations. Have you? – jay613 Oct 10 '23 at 10:16
    @jay613 It’s theoretically possible, but the ground would need to be completely impermeable to water for it to actually happen. Then you just need something (erosion, shrinking, etc) to create a thin gap around the basement is theoretically all you would need to float the building if the building is light enough (see https://physics.stackexchange.com/questions/304245/can-a-ship-float-in-a-big-bathtub for an explanation of the physics, the principles are the same). The likelihood of that actually occurring is essentially zero though because of how foundations are usually constructed. – Austin Hemmelgarn Oct 10 '23 at 11:58
    LOL @jay613's "house-planet detachment"... :D – FreeMan Oct 10 '23 at 13:36
    It definitely happens that empty concrete swimming pools float out of the ground. I've never heard of it happening to a basement... – Glenn Willen Oct 10 '23 at 16:49
  • *Hurricanes and heavy thunderstorms happen, and seem to be happening more* => clarification, it's not necessarily happening more often. I.e. the frequency of hurricanes in the Atlantic hasn't changed over the past 150 years. It's happening more often in some regions and less often in others. – JonathanReez Oct 11 '23 at 14:41
It's quite possible to have an external sump, if that's put in at build time it doesn't even cost a lot more, since the basement area has already had a large hole dug to put the basement in. Most people don't...
Better yet is a drain sloping downhill to daylight that does not need a pump, so it does not depend on power to the pump - but terrain must allow that, and the ditch for the pipe needs to be dug at a small extra expense.
Many basements are indeed built with the hopeful, but incorrect (virtually always) belief that they will keep water out.
Then they don't, and water needs to be removed from below the basement so it does not get in. It costs easily 10X as much to install an external drainage system at that point, since everything has to be dug up again, so chopping a hole in the floor for a sump pit is a lot more affordable, and that's what's normally done.
Some builders build one in to the basement in the first place, presumably because their customers expect to see them, and explaining an external sump might confuse some, and anyway it would cost a tiny bit more at build time that would not be recouped at sale time, which is math that builders don't like.
You invite the water that is under and around your basement to collect in one place where you can easily send it somewhere else.
Waterproofing is preferable but not all basements can be waterproofed. Some examples: Ones with floors built without waterproofing, ones with old walls made of permeable stone, ones with below-grade entry doors for cars.
Sometimes a sump pit is a lot cheaper, and just as or MORE effective than waterproofing an existing basement with water problems.
"The basement is dry except where the sump pit creates a penetration" is incorrect. Without the sump pit the basement would be wet. The sump pit is part or a drainage system, usually perimeter drains that direct water away from the basement floor and into the pit. And yes, sure, without the rest of the sytem (drains) and without the pump, the pit all by itself would be an accelerator for water entry.
jay613
  • 34,254
  • 136
If you have high ground water at times, then you want to pump down that ground water to below your floor's elevation. The sump pit exposes the ground water so that the sump pump can lower it to an elevation below your slab. Without it, you would at least have a humid basement. Without it, you might even need a pump sitting at your basement's low point to pump away periodic puddles.
popham
  • 5,193
Done properly, a sump pit can be as well sealed as the rest of the foundation.
Note that even if your basement is watertight, and stays watertight (cracks can develop, and go unnoticed until there's enough water pressure for them to leak), there's always the risk of a burst pipe causing flooding from inside the house. A pump guards against that, and a sump pit let's the pump keep the water level from rising above the floor, as well as permitting the pump to run more efficiently.
keshlam
  • 27,539
  • 46
  • 94
In many cases, a sump pit serves as a collection point for drainage pipes, sometimes called "drainage tile" but generally made of plastic, into which water will seep if the ground around the basement is wet. Although it might be possible to make a basement waterproof, it's generally better to keep the ground around the basement dry than to rely upon the concrete to resist water pressure without any leakage. While it might be possible to have many pumps scattered throughout the drainage tile, it's generally easier to have a pit that's lower than any of the drainage tile, thus allowing water to flow out of the tile using gravity alone, and then use a single pump to lift all of the water that has entered any drainage tile anywhere.
Incidentally, such systems are also important for things like window wells. Water that enters a window well will generally have an easy path into the drainage system, allowing it to be pumped out via the sump. Even if a basement was completely waterproof, a pump would be needed if there wasn't anyplace below the bottom of the window well where water could leave the property by gravity alone.
supercat
  • 1,018
