I hired someone to install. They used dirty hands to sloppily apply the caulk. It’s all over - clumpy globs of dirty caulk in the seams. And on the shower walls. I need to remove it and do it right. But I don’t want to scratch or remove the shine of the new walls. How do I clean up this mess?
Asked
Active
Viewed 66 times
1use something softer than the walls. a credit card or worst-case rubber spatula is safe; test first on a hidden area. – dandavis Oct 24 '23 at 03:58
A plastic putty knife should do it. There's a caulk softening product called Goo Gone. It might not be compatible with acrylic or whatever that is, do a test if you end up using the stuff. – popham Oct 24 '23 at 04:27
Also a steam cleaner is a great way to soften up the caulk and weaken it's holding power. – dandavis Oct 24 '23 at 05:00
If this was just completed, withhold final payment until the installer cleans it up. This is shoddy workmanship and not holding the worker accountable makes her think she's done a fine job and can continue to do it this way. – FreeMan Oct 24 '23 at 12:11
You need a commercial caulk remover & a plastic scraper.
Example images from Google for "acrylic caulk remover"
Tetsujin
- 10,454
- 1
- 19
- 37
