I am trying to match a new deck color to an existing deck that was stained with Olympic Maximum stain and sealant in the “natural tone cedar” color. I purchased the wood rx product in the cedar color hoping that they would match pretty closely. They do not. Can I mix the Olympic Maximum with the wood rx to try to match the colors closer? I believe both are water-based. I have probably just enough of both left to finish the new deck.
The deck to the right is 2 years old. Stained with the Olympic Maximum 2 years ago. I recently pressure washed it and then applied one coat of the Wood rx.
The left deck is new. It has one coat of wood rx on it.
brhans
  • 6,263
Danielle
  • 33
You can try - likely there will be noticeable difference of new to old until 2 years difference is an insignificant part of their time in service.
It's hard to predict how mixing the two products will go, even if both are waterbased. Try mixing only a small amount as a test.
