I'm building a house (brick, cement and concrete) and I have a big pile of wood used for beam and pillar molds.
How can I properly clean cement off wood? I think it should be very damaging to blades in general (planer, table saw, etc), and sanding it out wouldn't be very effective.
Luiz Borges
  • 2,315
  • 68
  • 80
    Its too late now, oil (motor oil) wood before using as concrete form. – HerrBag Jun 07 '13 at 20:52
  • Do you need the wood at a standard size? If not, resawing with a cheap blade (after knocking big pieces off, ala longneck) – HerrBag Jun 07 '13 at 21:02
  • Not really, is just wood that I want to re-use. In this case the problem is that I don't have a bandsaw. They don't have chunks of cement attached, is more like cement that was in contact, smeared or dripped. – Luiz Borges Jun 07 '13 at 22:30
  • @herrbag but then you're left with oil-soaked wood. Sounds worse that concrete. ;) – DA01 Jun 08 '13 at 02:05
  • @DA01 you pretty much commit the lumber for form use. It would burn nicely. – HerrBag Jun 08 '13 at 18:19
You could try X'Crete which is advertized as suited to removing concrete from forms. It dissolves the concrete into a slush you can rinse away. There's probably other similar products.
Or a more hard-core approach would be to use Muriatic Acid; apparently that's what masons use to clean their stuff. Downside being it's dangerous.
A more tool-oriented approach would be a belt sander with a low grit paper. Belt sander don't care.
Bryce
  • 526
Knock it off with a chisel and a hammer, then plane it.
longneck
  • 21,108
  • 48
  • 79
