I have a 2 x 4 framed garage. Years ago I insulated it with R13 fiberglass batts. Then I wrapped the whole garage in 1 inch EPS (R4), and put T1-11 over it. This worked just fine when it was a shop.
Now I am trying to work with the city to convert it to an apartment. They require the walls to be R-21. The interior walls have a complete wall of 3/4 inch boards nailed across the studs (100 years old). So I can't just fur out the walls to the inside and put in R-19 batts, without removing these boards, which may or may not be structural at this point.
I thought that I could just put in 1 inch of foam on the inside to achieve R21 (R4 + R13 + R4). But I am worried about a mold sandwich in between the two layers of foam. Yet after doing some reading on this, I am not sure I should worry.
So as it is, from the outside, it's 1/2" t1-11, 3/4" furring strips, 1" eps, 3/4" tongue and groove sheathing, true 2 x 4s with R13 insulation, and 3/4" boards on the inside of the wall.
Does anybody have any thoughts on this wall assembly, and the best way to get it to R21? Thanks.
