I recently looked round a house and put in an offer. There is visible damp underneath every window in the house. Would this be solved by replacing the windows? Or is there likely a more serious cause of the damp?
Asked
Active
Viewed 50 times
2That's why you don't buy before having a survey done. – Tetsujin Nov 06 '23 at 13:50
1Yep. All offers should be contingent upon professional inspection, and subject to negotiation to fix any problems the inspection finds. – keshlam Nov 06 '23 at 14:04
Could you provide a better picture? It's hard to tell what we're looking at with the one you posted. – SteveSh Nov 06 '23 at 17:16
There could be several reasons:
- Rain coming through an open / improperly closed window
- A leaky roof
- Leaks around the edge of the window, eg cills
- Condensation forming on the inside of the window and running down
- Faulty guttering causing water to run down the outside and come in somehow
- Water crossing the wall barrier - eg bridging across a cavity or soaking through a porous solid wall
- Condensation forming on a cold wall surface, eg an uninsulated wall or one with the vapour barrier in the wrong place (eg a breatheable wall covered in non-breatheable paint)
With any damp problem you need to take a whole-system approach: it may be that there's a series of faults that chain together. For example a faulty gutter and then an improperly sealed window allowing rain water to come in.
If you don't know what you're doing, professional advice is strongly recommended. You may have a hypothesis as to why it's happening, but somebody experienced may be able to make a better judgement.
If possible, it's a good idea to inspect on a rainy day, since if it's caused by rain water you may be able to see what the water is doing directly.
user1908704
- 1,212
- 6
- 10
