We bought a house awhile back and removed a wall we think was there to divide the kitchen from the dining room. We wanted a more open concept. Just want some assurance the wall was not load bearing. We have vaulted ceilings and the wall was not connected to the peak of the ceiling.
Asked
Active
Viewed 66 times
A load bearing wall should be supported underneath by a beam/wall on a cement floor/footings. Close to the centre of the house is another sign. Not having the roof falling down yet, is a also a possible sign it is/was not load bearing. Having an engineer/building contractor check the wall before removing it and hoping the roof does not fall down is money well spent. – crip659 Nov 08 '23 at 23:44
A few images of the current configuration and a layout sketch of where the removed wall was could be helpful. – popham Nov 09 '23 at 00:33
2You've asked the [same question twice](https://diy.stackexchange.com/questions/286371/trying-to-see-if-wall-i-removed-1-5-years-ago-was-load-bearing). Please delete one of these and consolidate all the info and pictures into the other. – FreeMan Nov 09 '23 at 01:10
Ruling a wall as load bearing can be somewhat easy. Just find a familiar pattern for load bearing walls and you're done. Ruling a wall as non-load bearing, unfortunately, requires the complete exclusion of all load bearing wall patterns, and even then there's a possibility of something "clever" (turns out it wasn't so clever after the place collapses).
The roof hasn't collapsed yet. That's pretty good empirical evidence, but if the roof hasn't seen a substantial snow load between your "awhile back" and now, then now would be a good time to bring in an expert.
popham
- 5,193
- 12
- 23
