I have a house with fungus on the walls as the roof was leaking and the house was empty for a while and not ventilated. I am fixing the roof. However, I'm cleaning the fungus / mold from the walls but this is very difficult. I doubt whether it is good enough to be able to paint.
I thoroughly treated all the walls with fungus or mold in the bedroom (15m2, approx. 2.3 meters high) with a firm brush and bleach solution. And also in some places with HG and Bison antifungal cleaner. I have treated the wall three times now but I cannot remove the brown colour. The sharp dots are gone but the brown haze remains (see photos). If I scrub very hard, it diminishes slightly, but it remains visible.
What would you do with these walls? Can I paint yet? Or do I have to treat first?When I sand the stains, the white of the wall below shows up (see white part in photo). It looks like I could sand the stains off the wall. Now I'm unsure whether I should do that as sanding can also cause you to rub the dirt deeper into the spot.
And do I perhaps need a construction dryer? I have used about 10 liters of water each time, part of which has been absorbed by the wall. I have now let it ventilate for a few days so that it can dry.
Thanks for the help!
See photos here
NiKoNi
    please paste the pictures into the question... use the button that looks like the moon and mountains – jsotola Nov 12 '23 at 22:44
  • What are your walls covered with? In the US (and other places) it might be drywall/plasterboard/similar, which would probably be much easier to remove & replace than it would be to clean. – FreeMan Nov 13 '23 at 11:45
  • Sorry, I removed the links and added photos here. – NiKoNi Nov 13 '23 at 23:39
  • I believe the walls are plaster. The are definitely not board or drywall. – NiKoNi Nov 13 '23 at 23:41
0 Answers0
