I'm not a plumber by any means, but my kitchen renovation is already very over-budget so figured I'd attempt to connect my sink plumbing myself. I haven't glued this together, it's just dry fitted, but I wanted to see if everything looked right first or if any adjustments would be needed.
Before, there had been an S trap, which I know isn't up to code. I did a lot of research and learned that I needed an AAV to work with a P trap since the drain is in the floor and not the wall. From what I can tell, the only requirements were that it should be placed as high as possible (with a min. of 6") from the horizontal P trap pipe and I think I saw somewhere the pipe needed to be at least 4" from the P trap to the sanitary tee. Does this all look right?
