I am installing a EV charger for my car in my garage and I've been all over the internet with a dozen different calculators and they all give different results for what AWG i need to use for my install. some say 1 AWG and some say 6 AWG, I'm pretty sure i need to use 3 AWG but want to verify.
The charger will be on a 100A breaker drawing 80A continuous at 240V and it will be 30ft from breaker to charger, 2 hot and a ground, NO neutral line required, and it will be run inside a 1 inch schedule 40 conduit. Also please correct me if I'm wrong but the ground line can be smaller than the feed lines like if i use 3 AWG for the hot i can use 4 AWG for the ground.
And yes i need the 19kW charge speed, because sometimes i will need to arrive home with like 10% and need to do a turn and burn. at 19kW i will gain about 18kWh every hour at that speed so after 2hr i could be up to 30-40% which is enough to get to a DC fast charger along the road to my next stop. Also yes if i am just plugging in for the night i can adjust the charge speed down in the car to 40A for a more standard overnight charge. But i need the ability to have up to the full 19kW the car can pull from the wall on AC. Besides the charger is only $400 and i bought it a couple years ago for when i finally bought a house.
