I recently got some contractors over to repair a section of my house and they unknowingly spilt a small amount of acid on my marble floor.
They did not attend to it immediately and the acid corroded the surface of the marble floor.
How do I repair it?
Japster
You would normally clean marble with etch spots with hydrogen peroxide or bleach and then repolish. From the sound of it yours may be more severely damaged. I would try both on a small spot and see how it goes.
If your marble is actually corroded then you will have to polish until you hit uncorroded marble.
DMoore
  • 47,764
  • 190
  • What sort of compound or chemical should I use for polishing? – Japster Jun 19 '13 at 05:55
  • baking soda and water - flooring stores also sell marble solutions. Also on your "stain" if you see that it is coming out a little with bleach or hydrogen peroxide. You may need to let these sit on there for a long time. You can do that by mixing hydrogen peroxide (or bleach - I would do them seperate) with paper towel bits and letting the paper towel bits sit on stain until it is dry - which may take a day or so. And if something is working keep doing it until the spot is gone. It may take repeat cleanings. – DMoore Jun 19 '13 at 06:03
Corrosion of marble (a form of metamorphic limestone) is not a stain, but rather a dissolving of the base rock.
The solution (if not too deep) might involve surface grinding, honing and polishing in place, but is not a DIY project. Discuss with a marble installer/fabricator.
Another solution (if the marble tile is available) is to replace the one tile.
HerrBag
  • 12,104
  • 37
  • I was assuming they were using the word corroded, when it really was a stain. They might as well treat it as a stain because if it is corroded its not really a DIY unless you can still find the same tiles. – DMoore Jun 19 '13 at 20:50
