I have four brick posts that are about four feet high and square (1.5 bricks per side all the way up). They are going. A tree hit two of them and I was probably going to take them out anyway. So I have a bunch of bricks with some of the bricks the mortar is attached. Throw them away or use for fire pit - is it worth the effort? Also will one layer of brick be too wobbly for a rather large fire pit - 4 feet by 2.4 feet by 2-3 feet high?
DMoore
  • 47,764
  • 190
  • FYI the "easy design" part of your question is far too subjective. I'd suggest you remove that part of the question. – The Evil Greebo Aug 01 '13 at 19:36
    @TheEvilGreebo - can't you just let me be a little lazy? – DMoore Aug 01 '13 at 20:20
    I thought one of the attractions of used brick was it's easy recyclability for use in other structures? – Fiasco Labs Aug 01 '13 at 20:32
  • Will one layer hold up in this big of a pit? what is the strongest/quickest way to hold them together well? I put very big branches in my backyard to burn. – DMoore Aug 02 '13 at 00:54
  • That's a big fire pit. I'm sure the bricks will work (if you re-mortar) structurally but not sure aesthetically. But that's your call. – DA01 Aug 02 '13 at 02:11
  • I have 40 trees in my yard and a lot of them are big oaks. The branches need to go somewhere and I do not believe in using curb service for this. – DMoore Aug 02 '13 at 04:13
My vote is always for re-use (except the trash pieces, which can still be used as a filler). For your question of using a single layer of brick (I assume you mean vertical layer for the walls) -- bad idea without lining it with steel or firebrick, and a quick way for people/things to get burned. You can also use two layers spaced with an air gap or filled with loose or crushed rock (and you can use the trash pieces as well so you don't need as much rock). You will want to mortar the bricks (mortar), not stack them, and you'd need a solid base. I'd recommend using this information from The Family Handyman as a fairly good guide.
Otherwise, build a proper firepit and use the bricks for a walkway or as a flat area for standing/seating around the firepit. I'd suggest knocking off the larger chunks of old mortar with a rock/brick chisel.
Jacob S
  • 841
I have used recycled bricks to build a small separating wall between me and the neighbors, no problem. I would definitely reuse them.
amphibient
  • 7,357
  • 47
  • 122
  • 194
A fire pit with used bricks should be fine. Are the bricks solid? If so I would definitely use them for a fire pit. At 2 - 3 feet high I brick wide will be OK, but I certainly wouldn't go much higher.
Good luck with it!
