We've recently sent our doors for stripping of many years of gloss paint and lead based varnish. The oak doors came back looking largely fantastic. As the doors are very old, understandably they have lots of old screw holes on their fascia which have been filled with some nasty white filler of unknown age. I've dug the filler out and now have good looking oak doors with small holes around the edges due to previous fittings. I have two questions:
  • What to fill the holes with so that I can varnish or oil to bring out the best in the wood and colour match?
  • If I pack the holes with e.g. matchsticks can I sand over the holes with wet PVA to create colour matched "dust" and expect to be able to varnish over this successfully?
We've stripped doors before and know that we need to wash down and leave to dry for several weeks and are being patient for now.
Kate Gregory
  • 1,417
Sorry, but this will be more difficult than you may think, at least if you are looking for it to look great. (I am a perfectionist on these things, and everyone has different goals and flaws they are willing to accept. However, you might be disappointed if you hang a door that you are not proud of.)
Suppose you fill (as indicated) with matchsticks, and any type of dowel. Those spots will have end grain showing, which will be extremely noticeable, especially if you then stain. The end grain will absorb stain differently from the rest of the wood.
Similarly, suppose you fill with wood filler or just a paste made of sawdust and glue. Again, it will not have the same characteristics as the surface wood. It won't look right. Of course, it depends on how large the holes are.
You might try a plug cutter in a drill press, used to cut face grain plugs to match the grain of the wood. Now, drill the holes out with a sharp drill bit, so the plugs will fit perfectly. A tiny dab of glue on the plug, and it is there to stay. Now you will have face grain set into face grain. If you are careful to get a nice grain alignment match, this can be made to work very well. And since you can buy plug cutters of various sizes, you can fill holes of many different sizes.
plug cutters
Once the plug is set in the hole, sand it down to be perfectly flat to the door surface. I rarely even wait for the glue to set, since it will do so in good time. Anyway, the sanding dust as I sand mixes with any glue present to fill in even any tiny imperfections around the perimeter of the hole. Note that plug cutters do not work well in a hand held drill, but you can get an attachment for many drills to make them work like a small drill press.
In the case of a really large hole that needs filling, you can always use a router to cut away that area to get a region with nice clean edges. Now if you do it properly, a template guide in the router will let you inset a Dutchman, again, with perfectly matching face grain.
Alternatively, one might try veneer patches, but for an outside door, veneer will likely not hold up well.
For those with some artistic skill, you might also consider faux painting any patches. Here you essentially paint on fake grain in any patched areas, made to match the door. Such faux grain can be very convincing, and with a good finish on top to protect is, this might be acceptable.
Make sure you find a piece of wood for these plugs that matches the grain of your door. All oak is not the same. You said oak, but there is white oak and red oak: even within those subspecies, there are different colors and grains. It even matters how the wood was cut, thus quarter sawn versus flat sawn wood. These woods have very different looks. Find a hardwood lumberyard to select a piece of wood that will match. If absolutely necessary, bring the door along and get help from someone there to find some wood that will be a perfect match. Or you might bring a close up color picture of the door to compare the grain & color.
A few final thoughts:
  • Use a good glue that is rated for exterior use, so it will not be a problem with potentially wet conditions.
  • Since you are looking to match the existing wood, I expect you will apply varnish (or some variation of clear coat) on the door when done. Use a high quality coating that is rated for exterior locations. This should have components in it to resist exposure to the sun, rain & snow, as they are tough on such finishes.
Pre finish: Filling with sawdust and carpenters glue (PVA) is the standard. It has the drawback of not accepting stain evenly. Hardening putties can be blended for color match (don't fully blend them for a more natural look). I doubt either technique will look good under an oil finish. A film finish (varnish, urethanes) would look better.
Post Finish: Small holes (up to 1/4" or so) can be filled with wax repair sticks. Several colors can be blended "in-hole" to nuance the fix. These would be used after the door is otherwise finished, and buffed with a soft cotton cloth. This technique works after either an oil or film finish.
HerrBag
  • 12,104
  • 37
One answer points out the gold standard - inserting a plug or patch of exactly matching wood. YES. (But hard.) Several answers point out using fillers stained to come as close as possible to match the wood. (Practical, but usually far from invisible.) A major problem is the grain.
One solution is to fill and stain as close as possible. Then tease up the finish with wood markers such as these. Mark thin lines of darker colors to simulate the grain, and experiment with wiping with a rag moistened with alcohol. Take spracie but you can often get a near invisible repair.
bib
  • 33,635
  • 100
Leave the matching to the next-to-last step ...
1) leave the holes as they are
2) finish the door completely in desired manner
3) fill the holes with a similar colored wood spackle
4) sand smooth without creating a dimple or sanding through the finish
5) buy a few tubes of similar artist paints and a small artist paint brush
6) create a faux finish to conceal the wood spackle (or hire a interior house painter with faux finish skills)
7) apply a final coat of finish to the door
mike
  • 3,010
