12
What are some devices that could slowly lower and raise roughly 200 pounds roughly 2 feet?
I have been looking at hydraulic equipment, but they are all designed for tons and i do not need the ability to lift that much. I would like the device to be small, lightweight and self sustaining. I do not want to have to charge, fill with liquid, check for leaks, replace after a year... stuff like that. I want to install and forget.
I need it to be able to slowly lower and slowly raise.
My goal is to have a device that can lower and raise a desk.
prolink007
  • 221
  • Related: http://diy.stackexchange.com/questions/1928/how-do-i-make-a-height-adjustable-desk – Steven Aug 22 '13 at 16:53
  • @Steven, already seen that. But i am asking about a specific device to raise and lower. Not about how to build a desk. My question is more specific. – prolink007 Aug 22 '13 at 17:07
  • Did you ever end up building something? I'm looking into the same right now. – Jed Daniels Jul 28 '14 at 19:24
  • Not yet, probably going to be purchasing a table. Seems like too much work for the space i currently have. – prolink007 Jul 29 '14 at 13:40
6 Answers6
Cam and follower
Cam and Follower
Gears
Linear Gear
Hoist
Hoist
Lever
Lever
Linear actuator
Ball screw
Ball Screw
Hydraulic cylinder
Hydraulic Cylinder
Jackscrew
Jackscrew
Leadscrew
Leadscrew
Linear motor
Hyperloop
Pneumatic cylinder
Pneumatic cylinder
Rigid chain actuator
Rigid belt actuator
Rigid belt actuator
Roller screw
Roller Screw
Segmented spindle
Segmented spindle
Telescopic cylinder
Telescopic cylinder
Winch
Scissors mechanism
Scissors mechanism
Windlass
Weightlifter
Sorry to revisit an old thread, but having recently been pondering the same thing I have settled upon a solution that fits my setup.
I have an ikea mikael desk with glass top - it has full width wooden sides rather than legs and weighs a total of 30+ kg unladen (see https://farm3.staticflickr.com/2438/3857538226_ab3914ea19.jpg). With monitors etc on board it comes in at around 50kg.
I decided to use gas springs, the type you get on cars/campervans. I bought a pair or them for £23 (about $35) from fleabay which have 25kg lift and a stroke of 290mm.
These will be attached to the sides of the original desk and to a wooden bar which will sit on the floor, parallel to the sides. I also stumbled on an adjustable clothes rail (like http://www.amazon.co.uk/Premier-Housewares-Double-Hanging-Wheels/dp/B008VB2PPS) which has 4x adjustable length bars. I was given this and it has sat in the garage for a while. There are cheaper versions which should do just as good.
The 4 adjustable bars are made up of 2x poles which slide over each other, and a small locking mechanism which clips across. This mechanism won't hold much weight, maybe only 10kg max per lock, so wouldn't do to hold the whole desk up. The larger of the two poles attaches onto the original desk at the top and near the bottom and the locking mechanism sits underneath the join, with the smaller one attached to the new foot running parallel with the original side. One adjustable pole will be near each corner. The gas spring will run from the new foot to the original side and assist in lifting the desk - which should have an effective weight of only a few kgs now.
The extendable poles should keep everything running smooth and even, allowing the desk to lock at whatever height is required, and unless there is a lot of weight on the desk I should only need to lock the front, easily-accessible ones.
With a few bits of timber which I had lying around, the whole project should cost me in the region of £25 or so - if you were to buy everything new it may be £50. It's very much designed for my current setup so may not be suitable for all!
If wanted I can post a few photos on completion, maybe a video of it moving. I can imagine that most people have managed to solve their problems by now though!
Tom
  • Tom, there is no such thing as an old thread on stack exchanges. Re-visit all you want, new ideas are always welcome. Pictures and video would be awesome. I would like to see the finished product and see if it works well. I am still looking for a cheap and manageable solution. Thanks – prolink007 May 29 '14 at 14:01
  • Here's a few photos of the completed desk - not looking too neat but not too bad either. http://imgur.com/a/uohM9 Original desk height is 77cm, raised height is 106cm. It is justa bout right for standing at and locks out perfectly. The only issue is that the gas springs are maybe slightly too strong - they could do with being 20kg each not 25 to make it better balanced. Other than that, I'm happy! – Tom Jun 03 '14 at 15:21
  • Thanks, that looks about what i was wanting. So, those rods seem to be working out fine? – prolink007 Jun 03 '14 at 16:11
  • Yep, no problem. Just make sure you have decent guides to keep everything lined up and level and you'll be fine. – Tom Jun 04 '14 at 13:03
What about pneumatic lifts, something like this?
gas lift
You would need additional hinges and attachment points, and might need a bigger version (at least a pair), but the approach might work.
Note that these are generally used with a rotational hinge, but you might be able to combine it with some other hinges or levers to raise something straight up as well.
SUPPLEMENT (in response to comment questions)
One end of the lift is attached to a stationary object, like a wall, and the other to a platform that can move, like a hinged shelf. Usually there is a stop at least at the lower range of the platform. The lift is like spring that is under compression. You lift the outer edge of the platform and the gas lift provides an assist (reducing the weight). If it is perfectly balanced, the lift will hold the raised weight in place. Or it can be latched when it reaches its upper limit. Some gas lifts are adjustable in the amount of lift they provide. Going down is the same. Your hand pressure overcomes the resistance in the system and the lift slowly lowers the weight.
SUPPLEMENT 2
An alternative might be a pulley system, like this bike pulley setup
bike pulley
This system has a 4:1 advantage, so a 200 lbs. weight would feel like 50 lbs. You would probably need two systems for stability, and the effective weight would be 25 lbs. of pull needed to lift 200 lbs. This, of course requires that you can find very strong anchor points in the ceiling, bolted into the framing, not just the finish material.
bib
  • 33,635
  • 100
  • How exactly does a pneumatic lift work? How do you get it to lift and lower? – prolink007 Aug 22 '13 at 16:23
  • For instance, does it lower slowly by me just pressing down on the rod? How does it raise back up? – prolink007 Aug 22 '13 at 16:38
  • Thanks for the explanation of pneumatic lift. I am not a big fan of the pulley system. Currently live in an apartment and i would have to have someway of stabilizing the desk so it will not sway or move. – prolink007 Aug 22 '13 at 17:09
  • I am going to see if I can find a place to get a pneumatic lift off some sort. Thanks for the help, will accept if it works out. – prolink007 Aug 24 '13 at 16:08
A scissor jack may be your answer.
scissor jack
  • I am not a big fan of the scissor jack for two reasons. When i lower the desk to sit, the jack may be in the way of my knees. Also, there will be lots of cords and stuff hanging off the back of my desk and i do not want them to get caught in the arms of the jack. – prolink007 Aug 22 '13 at 16:04
If it's OK to suspend it from the ceiling, perhaps something like this cable-lifted storage rack can be used:
user2813274
  • 211
I had exactly this problem and solved it with some of those quick grip clamps (that might be a trademark, mine were made by Irwin, but there are many equivalents). I reconfigured it to be in spreader mode. The bar sticks out on one end, so you can either point them up and use the clamps in pairs, or put it under the center of the desk with the bar pointing down if you set it on a sturdy box taller than the protrusion.
I liked this method because I didn't have to buy anything I didn't already have. I used to to raise my desk surface (fully loaded with 3 monitors, 2 computers, and 1 heavy UPS) 17 inches while I adjusted the supports. To do it safely I took turns raising each end, and adjusted the supports in small increments as often as possible to prevent any disasters.
skiggety
  • 561
