We have a bay window with normal wooden venetian blinds. The bay window has 5 individual blinds like this (http://www.mainfineintl.com/documents/FauxWood1.jpg) which use a twisting rod to open and close them.
Is there any simple way to link the rods together so only one has to be turned to rotate all of them? I'd like to be able to control all with one synchronously - we normally have them all open or closed at the same time so independent controls isn't needed.
Thanks.
BMitch
  • 42,687
  • 197
nLinked
  • 221
We have the exact same situation (bay window with 5 panes and 5 independent blinds) and I have toyed with the idea of mechanically ganging them all together.
The point where the twisting rod enters turns a cam which is coupled to a pulley system to tilt the slats. I posit that an appropriate line wrapped around each "twister" could do all of them at once.
I have not attempted it though—not even had a look inside. The set of blinds cost over $800 and my wife is quite reluctant for me to perform experiments which could affect the appearance or function. And she doesn't mind one bit if it takes me 30+ extra seconds per day twisting each individually.
wallyk
  • 12,319
