I've recently begun designing and building structural updates to my house. For example, I've built some shelving units and a cabinet space. Everything has gone well so far, but I'm about to tackle something more significant, a self-designed backyard shed, and I want to be sure that it is structurally sound.
The design will have non-traditional elements, such that copying an existing design would not be straight-forward and could not be relied on.
Is there a software tool or online resource that can help an average DIY'er calculate the load capacity for different structures using different materials? For example, if I use a 2 by 4 here it will be able to hold X weight, versus using a 1 by 3 can hold Y weight.
Or maybe there's are rules like 2 x 4 braced every 2 feet can hold 200 pounds. If this is the case is there a book or website that can provide me with guidance like this?
Bob.
  • 93
    Welcome. This comment is meant to be helpful. Your wording "as structurally sound as can be" seems to be at odds with the sentences that ensue, which suggest you are looking for 'adequately sound, or a bit more'. You could tour similar sheds at HD or at a shed specialist's display yard to get an idea of what is adequate, then up it as desired. For software, there are BIM solutions which can be found through google. All the best. – mike Oct 23 '13 at 17:01
    The resource you're looking for is the locally approved version of the Building Code. – Chris Cudmore Oct 23 '13 at 17:48
  • @mike I updated my question to be less passive. It's simply about making project structurally sound. – Bob. Oct 23 '13 at 17:57
    +1 on pursing a creative design. For the integrity of the shed as a whole, a BIM solution is the way to go. For individual elements, see this thread ... http://diy.stackexchange.com/questions/13352/at-a-6-span-how-much-can-an-spf-2x4-turned-on-3-5-end-support – mike Oct 23 '13 at 18:16
  • @mike Perhaps this should be posed in a separate question, but do any simplified BIM software solutions come to mind for a DIYer? – Bob. Oct 23 '13 at 19:21
  • This looks like a useful design forum: http://www.revitforum.org/forum.php – mike Oct 23 '13 at 19:59
  • I use this site for floor joist and rafter spans http://www.awc.org/calculators/span/calc/timbercalcstyle.asp – Justin K Oct 24 '13 at 02:04
    When in doubt overbuild – Justin K Oct 24 '13 at 02:06
  • @Bob. - I see you've put a bounty on your question. Does that mean the suggestions offered so far by various users are not what you are looking for? – mike Oct 27 '13 at 02:45
  • @mike I'm hoping for a more definitive BIM software app or resource for a DIY'er. Also, you should move a summary of your responses out of comments and to an answer. – Bob. Oct 28 '13 at 14:31
  • [shed 1](http://i.stack.imgur.com/e2jRV.jpg) | [shed 2](http://i.stack.imgur.com/Z4svT.jpg) | [shed 3](http://i.stack.imgur.com/d8iZ3.jpg) | [shed 4](http://i.stack.imgur.com/DO79n.jpg) | [shed 5](http://i.stack.imgur.com/IRmAQ.jpg) – mike Oct 28 '13 at 18:29
  • @Bob. - I've rethought this. I'm now pessimistic. The sticking point is your 'non-traditional elements'. I can't imagine any company being willing to assume liability for the output software for arbitrary input ... or even being willing to have their name associated with the software. Sorry. On the other hand, I'd easily be willing to design and build the structures such as the above 5, and wouldn't lose any sleep over their integrity. – mike Oct 28 '13 at 18:39
  • http://www.readersheds.co.uk/ – mike Oct 28 '13 at 18:55
  • @Bob, crazy shaped sheds can still be mostly built using traditional box shaped techniques that are time tested. – Zach Jan 08 '14 at 18:17
  • @Zach Thanks for the thoughts... and to follow-up. What's a good resource (a book or two, or better, a website with videos) to learn about building with "traditional box shaped techniques?" – Bob. Jan 09 '14 at 18:52
Safe loads are determined through engineering and experimentation. The experimentation is used to gather real-world data, which then is used as input to engineering processes, which then result in guidelines and building codes.
This is all updated over time as new materials are introduced and new experience is gained.
When there's a situation that is non-standard, there are two common approaches to dealing with the situation. The first is to pay an engineer to provide guidance on an appropriate approach. The second is to simply overbuild. An experienced builder will know when it's okay to overbuild, and when you need an engineer.
To get back to your original question, it has no simple answers. It involves the materials used, how they are assembled, and what sort of forces they are going to be asked to deal with. If you can post more detail on your design, I can advise you on any deficiencies that I see, but I'm not a professional.
Eric Gunnerson
  • 2,909
  • +1. If something is worth doing, it is worth overdoing. Overbuilding. –  Oct 25 '13 at 01:26
