I am installing a closet system which is supported from a single track. The wall I am attaching this track to isn't a standard wall but a firewall between my townhouse and the next.
The cinderblock has a 2" thick stud between it and the drywall.
Should I go through the studs and into the cinderblock?
Is 2" deep enough to support the closet system?
The exact closet system I am installing is:
(source: homedepot.com)
Martha Stewart Deluxe Starter
Product:
http://www.homedepot.com/p/Martha-Stewart-Living-4-ft-8-ft-Classic-White-Deluxe-Starter-Closet-Kit-W1/202060751#.Um-4mvlUYz4
Instructions:
http://www.marthastewartclosets.com/instructions/680000-INS.pdf
Glorfindel
  • 1,173
iambriansreed
  • 502
Two inches is an odd size for framing material. It might be a 2x4 set flat, which is actually 1 1/5 inches thick.
It is highly likely that this framing member is attached to the cinderblock at several points. If this is so, there is no issue with just attaching to the framing.
If the framing is not attached to the cinderblock, it would be significantly less sturdy than a conventional wall in which the 2x4s are set on edge. In standard framing you are attaching to an edge that runs 3 1/2 inches deep. That means your setup would be more prone to bowing, especially in the middle, under the weight of a heavy load.
There are many factors that go into whether or not that would pose a practical problem. How heavy a load will be on the wall units? How far from the wall do the units extend? How many studs can you attach to for each mounting device or unit? How close to the ceiling and floor (the strongest areas) are the principle attachment points?
If you cannot determine whether the studs are attached to the cinderblocks, I would probably try to anchor into the cinderblocks, at least at several points, but not necessarily every point of attachment.
SUPPLEMENT
There are two forces at work in a wall hanging - downward and outward. Assuming the fastener is in a solid medium like framing wood, the downward force, shear force, is controlled mostly by the the ability of the fastener to resist being broken across its circumference. In general, standard screws and bolts are plenty strong.
The outward force is largely controlled by two things - the strength of the fastener in the support material and the rigidity of the support material. Again, standard screws or bolts in wood are up to it (these systems are designed for that). The problem, if any is the ability of the framing to stay in place.
The main support mechanism is near the top of the unit (that horizontal hanging strip), and the framing near the ceiling is fairly secure because the vertical studs are attached (hopefully) to some sort of top plate, spreading the load.
You are probably safe going into the wood. But if it were me, I would not rely on probably, and I would anchor into the blocks in at least three places along that top hanger. If they are hollow blocks, I would try to hit a hollow and use a toggle type anchor. If solid, an expanding masonry anchor.
bib
  • 33,635
  • 100
  • It is not a 2x4 it is a 2x2. I am aware that 2x4 does not actually mean 2 inches by 4 inches and should have been clearer about the size in my OP. Please see my update. The product weight itself is 85 lbs and that's before customization and clothes. I would say upwards of 300 lbs total. – iambriansreed Oct 29 '13 at 13:36
