12
I have a few L-brackets for hanging shelves. The brackets are asymmetric, where one L arm is longer than the other, just like a real "L" (similar to this).
Is there a preferred or recommended way for which arm, the longer or the shorter, goes on the wall and which under the shelf?
Adi Shavit
  • 223
Put the leg that best matches your shelf width under the shelf. That is why there's different leg sizes. The bracket's critical section is the inner corner, it is equally strong in both directions. That said, usually the critical portion of the entire assembly is the withdrawal of the upper wall screw. Having the long leg against the wall somewhat reduces this force. But if that results in a significant portion of the shelf unsupported, that could weaken the assembly more than the modest gain in withdrawal strength.
The best approach is to fully support the shelf and use wall screws that are long enough to provide plenty of withdrawal strength regardless which leg is against the wall.
bcworkz
  • 11,428
The long leg goes against the wall. You can do it the other way, but it won't be as strong.
Ali B
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably [take our tour](//diy.stackexchange.com/tour) so you'll know the details of contributing here. – Daniel Griscom Apr 13 '20 at 12:09
The long part goes against the wall, under the shelf. The length of the actual bracket under the shelf should be three quarters the width of the shelf.
Roger
It depends on if you want more clearance vertically or horizontally. They're 'supposed' to provide more clearance vertically, otherwise you'll lose more shelf space height on the one below it. Even if there's no shelf below, do it that way so you don't hit your head on it.
Shelf brackets shouldn't be sticking out of the wall at all, a full foot below it. (meaning it's the wrong way in your picture). The other way, it's more like just an 8" head-bonker.
Mazura
  • 13,357
  • 56
