30
When my dishwasher runs the kitchen sink backs up. I have a two tub sink and only the side nearest the dishwasher with the garbage disposer backs up. Running the disposal for a few seconds causes the sink to drain.
I'm not sure what to look at to address this problem. It doesn't strike me as a clog because if it was the sink would drain poorly.
BMitch
  • 42,687
  • 197
Freiheit
  • 4,162
  • 47
  • 67
  • Does the water just sit there until you run the disposal? Or will it drain slowly? – Niall C. Dec 14 '10 at 18:06
    I've had the same problem in both apartments and the house I've lived in. I just assumed it was normal due to the pressure in the drain line from the dishwasher into the disposal. My guess was running the disposal pumped the water down the drain. I've never put much down the garbage disposal, so I doubt it's from debris collecting in a clog. – Doresoom Dec 14 '10 at 18:16
  • good question. I have customers ask about this often. – shirlock homes Dec 15 '10 at 12:09
There is a very simple answer to your question. Your dishwasher is draining into the side drain adapter on your garbage disposer. this was a common practice for many years. All the water draining from your dishwasher is being pumped into the upper basin side of the disposer. Solids from the dishwasher are blocking the drain in the disposer, so when you turn on the disposer, it grinds the waste and drains the water. This is actually the way it is suppose to work. Current codes require a separate trap for the dishwasher and not plumbed into the disposer. If you look at the side of your disposer, you will see the hose from the washer attached there. Only fix is to install a new separate trap and drain for the washer. Good luck.
shirlock homes
  • 58,152
  • 84
  • 166
  • I didn't realize this code had changed -- thanks for the heads up. – Mike Powell Dec 15 '10 at 13:50
    Accepted. Describes my setup exactly and the symptoms match the explanation. – Freiheit Dec 15 '10 at 14:56
  • code changed? If so, why are new disposals shipping with this port? – Engineer2021 Dec 15 '10 at 23:17
  • @0A0D: Not all codes are the same in all areas, though it probably comes down to manufacturing. It's cheaper to keep making them with the port, rather than redesign them and change the manufacturing process. – Tester101 Dec 16 '10 at 17:12
    In most cases, replacing a broken disposer doesn't require adding the new drain, because the older method is grand fathered. If you were to have a plumber install a disposer today, say in a kitchen renovation or new construction then you would be required to do it the new way with the separate drain/trap. So the disposers are still avail with side drain for old work situations. – shirlock homes Dec 16 '10 at 17:16
  • 2003 International Plumbing Code which states: 802.1.6 Domestic Dishwashing machines. "Domestic dishwashing machines shall discharge indirectly through an air gap or air break into a standpipe or waste receptor in accordance with Section 802.2, or discharge into a wye-branch fitting on the tailpiece of the kitchen sink or the dishwasher connection of a food waste grinder. The waste line of a domestic dishwashing machine discharging into a kitchen sink tailpiece or food waste – Engineer2021 Dec 16 '10 at 18:05
  • grinder shall connect to a deck-mounted air gap or the waste line shall rise and be securely fasten end to the underside of the sink rim or counter." – Engineer2021 Dec 16 '10 at 18:06
  • so this tells me that the code is to still connect to disposal. – Engineer2021 Dec 16 '10 at 18:06
  • Time to update to the 2009 codes.Check with a Master in your area. I subcontract a ton of work to two different master plumbers here in Maine, and they both tell me the code has changed and all my work is permitted in the town of jurisdiction and the code inspectors tell me the same thing. There were huge changes in the new IRC codes. Sorry to disagree with you, but I defer to my experts that I pay a lot of money to. Six kitchens this year. – shirlock homes Dec 16 '10 at 22:15
  • BTW, an air gap is just another name for a trap. Not a drum and not a "P" trap. Yes you can still attach to the basin drain or pig, but the wye-branch must be below their respective traps. – shirlock homes Dec 16 '10 at 22:16
    2009 IPC says - 802.1.6 Domestic dishwashing machines. Domestic dishwashing machines shall discharge indirectly through an air gap or air break into a standpipe or waste receptor in accordance with Section 802.2, or discharge into a wye-branch fitting on the tailpiece of the kitchen sink or the dishwasher connection of a food waste grinder. The waste line of a domestic dishwashing machine discharging into a kitchen sink tailpiece or food waste grinder shall connect to a deck-mounted air gap or the waste line shall rise and be securely fastened to the underside of the sink rim or counter. – Engineer2021 Dec 17 '10 at 01:05
    @shirlock: It looks like nothing has really changed between 2003 and 2009. I agree that air gap is another name for trap. I don't mean to disagree, but I just had a brand new garbage disposal installed this year and a new dishwasher installed in 2009. It discharges into the food disposal dishwasher port and there is a high arc to allow for the air gap. Both were installed by certified plumbers. This is in Florida. – Engineer2021 Dec 17 '10 at 01:06
  • Ypu have definately peaked my curiosity now. I am gonna call my plumber and ask him exactly what the rule is. – shirlock homes Dec 17 '10 at 08:06
  • @shirlock: any news? – Engineer2021 Dec 23 '10 at 00:11
  • Am I to assume that the rule is correct? – Engineer2021 Dec 30 '10 at 14:41
This might be of interest.
Air gap
Many local building codes require a dishwasher to connect to an air gap before the connection to a garbage disposer. This keeps wastewater from backing up into the appliance. You must purchase the air gap separately. Mount in on top or next to the sink. Connect one flexible hose to the drain of the dishwasher, and connect the other flexible hose to the trap of the sink or to the disposer’s dishwasher inlet. If your local codes do not require an air gap, you can shape the drain hose of the dishwasher into a high arc instead.
  • Yup. Gotta have an air gap. – Bob Murphy Dec 14 '10 at 22:04
    Notice the "shape the drain hose of the dishwasher into a high arc" in the reference above. Try that too. – Jeff Widmer Dec 15 '10 at 02:01
    I don't think this is the answer to the question. As I understand it, an air gap prevents water from backing up INTO THE DISHWASHER. His problem is the sink backing up. I don't see how an air gap would fix this. – myron-semack Dec 15 '10 at 12:04
    Water is backing up into the sink not the dishwasher and I have an airgap. – Freiheit Dec 15 '10 at 14:53
  • I've had water run out the air gap from the dishwasher at my old place, but only when the plumbing got clogged. – Neth Dec 15 '10 at 18:50
As others have pointed out, the diswasher drain line probably connects to the top of the disposal. The diswasher drain line will dump dirty water and food particles into the top of your disposal.
Do you run the disposal prior to starting the dishwasher? If you have crap built up in your disposal, that can be contributing to a backup. The manual for my dishwasher says to make sure you run the disposal at the start of a cycle.
It is possible that your disposal is clogged slightly (constricted, but not completely plugged). You wouldn't notice when you run the sink, because your are putting clean water down the drain. The dishwasher waste water includes lots of solid particles, which would aggravate the clog. Running the disposal grinds the particles and pumps the water.
There are some foaming garbage disposal cleaners, I would try one of them. Look for an actual cleaner, not just a deodorizer. (NOTE: Use something specific for disposals, not general-purpose Draino.)
Another thing to look at: Dishwashers have a built-in mechanism to deal with food particles before draining. Otherwise the hunks of food from your dishes would clog the plumbing. Most dishwashers in the US have little garbage disposal type blades that grind anything in the waste water. Some dishwashers (notably Bosch) have a little strainer basket to catch the particles. The strainer basket needs periodic cleaning.
  • If your dishwasher has a built-in disposal, it may not be running properly, allowing large particles to slip by.
  • If your dishwasher has a strainer basket, make sure the basket isn't missing and doesn't have holes in it, which would allow particles to enter the drain line.
myron-semack
  • 3,443
  • 25
Your disposal is clogged. When you turn on the disposal, the water slowly drains because the motor slowly sucks the water out but otherwise is not operating properly. There should be a clear hose that goes from the dishwasher to your disposal. That is the drain line for the dishwasher. You can either use the hex key provided with your disposal to manually turn the disposal to see if you can clear the clog and also hit the reset button. If that does not work, then you will have to replace your disposal - it is likely shot.
Engineer2021
  • 3,285
  • 46
-1
An easy fix: Pre-rinse large gunk off your dishes before loading them into the dishwaher. DOn't expect the dishwaher to deal with lasagna and mom's meatloaf.
