I've got a Whirlpool over-the-range microwave that is currently venting back into the kitchen. I'd like to poke a hole through the wall and vent it directly outside. I've read the instructions and it seems pretty straight forward.
I don't know much about this, so my question(s) is: am I going to be "locked in" to this microwave? What happens in three years when I want to replace it with another brand? Is it likely that the exhaust duct will still line up? What if I replace it with a hood?
Aarthi
  • 1,143
Boden
  • 195
There is no standard mounting or vent hole dimensions for these type of microwaves. Although most of them adapt to 4inch vent hose, there is no standard to where on the back of the microwave the vent is attached, and this can effect where you need to cut your hole in the wall, especially in 2X4 walls where you won't have a lot of room to offset the vent.
shirlock homes
  • 58,152
  • 84
  • 166
  • If in the future I have to move the hole by a few inches, how do I handle things on the exterior? (hardboard siding) – Boden Dec 31 '10 at 16:54
  • You may have to cut in a new piece of siding if you can't offset the vent. Replacing a piece of siding is not a real hard job,BTW. – shirlock homes Jan 02 '11 at 13:43
The fact that there is no standard makes this a problem over and over again, which is why most people just let it vent into their kitchen.
A solution to this might be to vent up and then out. I'm assuming that this is mounted under a cabinet and over the stove (they generally are). Instead of going straight out the wall go up into the cabinet and then through the wall. this up and then out model might give you some play room if you switch to a different microwave or move up to a hood. you loose some storage space doing this but may be worth it.
boxed-dinners
  • 1,075
  • keep in mind that each bend in the vent decreases the efficiency in the air movement. each 90 degree bend drastically reduces the CFM. – mohlsen Jan 04 '11 at 13:50
You can get flexible aluminium hose, which I have used to deal with a situation where the appliance didn't line up with the outlet hole. It is not totally smooth, so there is the potential for a bit of grease build up (you could replace it every now and again, or put it in the dishwasher or something) and it will impair the airflow slightly (run as short a length as you can).
alt text
flamingpenguin
  • 1,324
  • Every vent install manual I've seen says you should not use flex in this application. On the other hand it's probably better than recirculating the air back into the kitchen! – Ben Jackson Feb 02 '11 at 02:15
    I think you can do it as long as it is a very short run. Don't run it all the way to the outside, I just use it to get to the smooth stuff. – flamingpenguin Feb 02 '11 at 18:18
