I have purchased a wrong door , Im a carpenter and don't know if its possible to change the door from a Right hand inward swing to a Lt hand reverse swing door ?
Steamrock
    In general, maybe. But a photo of the door would help. Is it symmetrical? Came pre hung? Was the lockset drilled? See also http://diy.stackexchange.com/questions/2784/how-do-you-determine-if-a-door-is-right-handed-rh-or-left-handed-lh?rq=1 – Bryce Jan 21 '14 at 06:58
a Right Hand Reverse door is the same as a Left Hand (push) door. You will have to flip the frame around or re-prep it for the strike and hinges though.
Nick
It will work just fine but do you want your hinges on the outside? If this is an interior door no big deal. If it is an exterior door I could get in your house with a pick and hammer.
DMoore
  • 47,764
  • 190
