I need to replace my wax ring on my toilet. To do that I need to turn the water off that fills the tank.
When I go to the valve that is by/under the toilet it will turn a bit more than a quarter turn. That is all. After that it is very stuck. Trying to force it seems to put torque on the little pipe coming out of the wall (though I admit I have not tried too hard because I really don't want to have to open my wall up to fix a messed up copper pipe.)
I am the first owner of my home and this valve has never worked (though I did not think to check it till way after my warranty expired).
So, is this a cut the pipe and put on a new one kind of job, or is there a better way?
Vaccano
  • 425
First, a silly question for you. Are you sure the valve is not a 1/4 turn ball valve, and are you sure it has not turned off the water supply to the tank. If the answer is no to both questions, then we have to assume the valve is defective and we go to plan two. Now you have two jobs ahead. First, replace defective valve with a 1/4 turn ball valve and second, replace the wax ring with rubber flange. Before you can attack the valve replacement, you must turn off the main water supply, usually found at meter or pressure tank. After you have turned off the water supply. open a couple of faucets that are below and above the valve you want to replace. This will drain water from the system and avoid a lot of water held in pipes above the toilet valve from rushing out all over the place when you unsolder or cut the old valve out. Without seeing exactly what configuration your valve is attached by, I cannot advise you if it can be unsoldered. Another option may be to secure the body of the valve with a wrench and see if you can remove the cartridge retaining nut with a separate wrench. This will avoid the fear of ruining the copper in the wall. you may be able to replace just the guts instead of the entire valve. A pic of your set up would be helpful.
shirlock homes
  • 58,152
  • 84
  • 166
    An alternative to soldering in a new valve is to use a "retrofit" valve, like this one: http://www.amazon.com/Watts-LFPBQTR-615-Retrofit-Straight-Fem-COMP/dp/B0042FAWRU/ref=sr_1_5?ie=UTF8&qid=1294559646&sr=8-5. It has a compression fitting (like the hose to your toilet) and just connects in front of the existing hose. Your existing valve just stays open all the time and can be ignored. – gregmac Jan 09 '11 at 07:57
