I'm doing a remodel and can't seem to find the proper method for installing the tongue and groove plywood subfloor over joists. I mean, I think I pretty much understand how to do it but there are a few details I'm missing still.
  • On the first sheet down, does the tongue or groove go towards the wall? Pretty sure it's groove based on what Bob Vila shows on TV
  • What adhesive should I be using to attach the plywood to the joists? (Be specific)
  • Nails or screws? And exactly what kind?
  • Where are expansion gaps required? Everyone says to leave a 1/8" expansion gap but they never say where that gap should be
  • How tight should the T&G be? Does it need to be glued or anything?
Joe Phillips
  • 2,246
  • 59
The plywood goes down so the groove is away from the wall, that way, after the row is finished, or at least when you decide to start the next row, a 2X4 can be placed across the joists at the edge of the next row and drive, with a sledgehammer, the second run into the first. The gap should be 1/8" between ends. The tongue and groove (T&G) of the sheets should be driven snug. Do not try to drive them tight, although in some cases it might be needed in order to keep a straight run. The first run is set to a chalk line, but the rows after that can start to meander after a few runs are down, and to correct it with a tighter fit or if need be, a loose fit to correct the run so it remains true
The subfloor adhesive I choose to use is polyurethane based adhesive. It has a long open time, Meaning you don't have to rush to get it covered before the glue "skins" over, thus minimizing the bond. Also, it is twice the cost of regular subfloor adhesive, but you can actually use less. Since there is no "skin" that will form that will need to be broke again by the laying of the plywood over it, to squeeze the glue again out of the skin that was formed by it sitting open before the plywood goes down. Do not drop the plywood on the glue or set the plywood off the final placement too far or firstly the glue will splatter all out off of the joist, or slide or scrape the glue off the joists. I seen both of these things happen in my years of construction. Needless to say the bond will not be worthy. The tongue or the groove does not need to be glued, although there is no reason not to. Some engineers require it in certain applications, but for standard subfloor applications none will be needed. Again it is to your discretion also. If you choose to place the glue at the groove, so the tongue drives it into the groove.
Screws are the best to secure the plywood with, and since a premium glue is used, there only needs to be enough set to draw the plywood to the joists. You can still place them as it has been done before the days of glue which is 6" on the edges and 8" in the field. With glue you really can spread them out farther, 5 screws used on the ends if you choose, and 4 across the field. There are drills that are sold that use screws that have the screws collated in coils or strips. Makes this go much faster. Rental is an idea here.
Again with the glue, nails can be used too, since the glue will do all of the holding after it has set. Air powered nailers are available for this and will be faster than screws, but the nail gun in some cases does not draw the wood together like screws.
Jack
  • 34,187
  • 60
  • Thanks for the tips. In my particular situation I'm doing a bathroom that is 8' wide so it fits one span of plywood perfectly and I only need about 3 sheets to do the entire length of the room. One question about your comment "The gap should be 1/8" between ends" -- I'm wondering what ends are you referring to? The sides of the T&G where it butts up against the old subfloor? – Joe Phillips Feb 10 '14 at 05:50
  • In my answer I was referring to the 4' ends, where there is no T&G. If you are butting up against subflooring that is in place and the edge is spanning across the joists, I would run 2X4 blocking flat between the joists at the old flooring to tie the joint together, the same way the T&G does it for the new subfloor. This would be glued and screwed together. Where the new and old meet, there should be a 1/8" gap there too. – Jack Feb 10 '14 at 06:01
  • I might add: "Why leave a gap at all?" Answer: Abutting ends WITHOUT mating tongue-and-groove will move. If there's no gap, you'll hear them squawking later when they do... Humidity will make them grow towards each other too. –  Oct 20 '15 at 13:59
  • Put the tongue edge in line with the edge of the floor system. Use a beater bar 2x4 to pound the next sheet (tongue) into the corresponding groove. If you try beating the tongue edge, you will crush the tongue and it won't allow the next sheet to fit. –  Apr 01 '16 at 16:58
  • Do i have to compensate the 1/8" gap when i do the framing ? – Miguel Trias Jul 03 '16 at 03:02
  • If you mean the 2X framing that is under the subfloor, no that needs to held tight in place the toenails or screws, at the most framing anchors suited to your conditions.If you mean the 2X block at certain edges mentioned above, yes it can be a small space, since it it used to tie the 2 sheets of subfloor together. If it is touching the framing then it should be securely fastened. Either way for that instance, will work. – Jack Jul 03 '16 at 03:09
    What i meant was, assuming my subfloor sticks are spaced at 16", the first two plywood sheets will butt exactly at the center of the 6th stick (because 16" * 6 is 8'). But after 4 sheets in the same row, if i add up the 3/8" gaps i get a 12/8" offset, which means that there's not going to be a stick below to nail to. So i wonder, should i space my sticks 16 3/8" instead? – Miguel Trias Jul 03 '16 at 05:34
    Plywood makers size the sheets to allow for the spacing. you should be able to keep 16" centers. The notation, "sided for spacing" may be on the sheets – Jack Jul 04 '16 at 00:48
