I want to put up a stone veneer surround, around a gas fireplace we're going to install. I've seen everything from using 1/2" plywood and a metal lath, to putting the tiles directly on drywall. I have everything apart so I want to do this the best way.
The tiles/stones I will be using are quite heavy as they are real stone and not "manufactured stone".
Items in play: - Weight - heavier tiles - heat - over and around a fireplace - Indoor
Dilbert789
  • 983
Drywall is out of the question due to weight, plywood might not give you the proper adhesion.
I would start with cement board, then attach the metal lath to that. After the metal lath is secure, you'll have to apply a scratch coat of a sand and cement mix before applying the stone.
Here is a good guide for applying stone veneer.
If you are using real Stone, one thing to consider, the wall doesn't support the weight , it just hold it from moving horizontally, any real Stone need a firm base to sit on like a heart or Concrete slab like your floor . This is called vertical load. The only attachment you need on the wall is a wall tie and a 8 penny nail. There should always be a hollow cavity behind the stone when laying. The wall tie is the mechanical anchor that transfers to the wood stud framing or shear wall. Fake Stone or stucco Stone is a totally different application, where cement board or lath is more commonly used.
If you use cement board, you'll want to use a polymer modified mortar or thinset for the installation. If you use plywood, you'll need to install a weather resistant barrier, metal lath and put up a scratch coat. They both have there pros and cons, but I would probably recommend cement board. Make sure its actually cement board and not a composite board like hardybacker. Unfortunately stone veneer tends to sheet off on composite board unless it's installed with a very good bonding mortar or thinset.
Dmason591
