I live in the Northeast, and we had a hard winter. Just a few small cracks in the asphalt. I went to home depot, but all they have are 5 gallon drums of sealer. To me, it looks like all I need is to do what the state does to the highways (thin stream of tar) in the crack.
What can I do for minor repair (rather than hire someone to re-seal the whole driveway) or on the other hand, perhaps I am wrong, and it is best to reseal the whole driveway?
Dr.YSG
  • 183
  • there are lots of sealers in 5 gal buckets, they are rated by years, 2 to 10 yrs. – shirlock homes Apr 29 '14 at 20:26
  • I have read that you don't have to (and probably shouldn't) seal every year. However, your instinct to treat the cracks in a timely way sounds good. There are squeeze, pour or caulk options that are a lot smaller than a 5 gallon bucket. – aparente001 Mar 11 '19 at 07:43
You first need to fill in the cracks. Home Depot has a variety of products available. Some are latex based that are easy to apply but probably best used for smaller cracks up to 1/2" wide. Others are cold patches that you have to compress with a tamper or by driving over them a few times. Some need to be heated with a propane torch. Those I believe are the strongest available but a little more involved. Do a search for 'asphalt patch' on the website and you'll a variety of different products.
An asphalt sealer is just a top coat. It is used to protect the asphalt from water, UV, and other things that can degrade the asphalt. Think of it like a sealer you would apply to a wood deck. It is not meant for patching. Many sealers can however fill in small cracks up to 1/8" wide. Check the labels. You'll want to reseal the driveway every couple of years or so depending on your local climate and conditions to protect it.
At my local Home Depot I see a few different sealers that are in 4 to 4.75 gallon sizes. Never seen them sell anything in stores larger than that. Those buckets they sell usually have a coverage anywhere between 300-500 square feet which is usually more than enough for an average single car driveway. You want to apply the sealer over the entire driveway because it all needs to be sealed, not just the cracks/patches. In addition to protecting your driveway it restores the color and makes it look like new.
OrganicLawnDIY
  • 3,721
  • 44
  • +1 for filling the cracks with a caulking style filler before applying the overcoat sealer. Up north, driveway sealer rarely lasts more than a few years, even the good stuff. – shirlock homes Apr 29 '14 at 20:28
