12
My tenants tell me that they hear an animal (possibly a raccoon) in the attic. This is an old (1880s) three story row house with a flat roof and a pretty low (2 ft average, maybe) attic. The house was totally renovated 10 years ago and I'm not very familiar with the attic situation or where the animal might have entered the attic.
I was told it sounds like at least a couple relatively large animals are scampering around the attic and occasionally they make whimpering growling noises.  They seem to be most active in the morning between 5 and 7 and I don't usually hear them during the day (maybe they are nocturnal or maybe I'm just not at home during the day).
How do I deal with the situation?
Edit: Alright, I betrayed the DIY principle and hired a professional. He found squirrel droppings and no proof of raccoons or any other animal. He found two wholes and filled them with metal screens attached with screws and Liquid Nails. He also put a trap and is going to check it in a few days. Cost was rather steep: $395 total. Next time I may do this myself. Although, honestly it was not an easy job for him especially in one of the corners where space was tight. Also, the dust, droppings and fiberglass insulation makes this job unpleasant.
Aarthi
  • 1,143
Victor
  • 143
6 Answers6
Not knowing where the house is limits the advice. However since it has a flat roof, I'm going to assume it's not anywhere where it snows a lot.
You need to get a professional for several reasons.
  1. In most states, as a landlord, you're required to do something and the only way you can demonstrate due diligence with something like this is court is to hire a pro.
  2. Animals carry lots and lots of nasty things, not just rabies (as if that isn't bad enough). If you trap it you risk injury, if you poison it then at some point you have to remove the carcass and ... gross.
  3. The professional should be up on whatever obscure state and local laws affect removing the animal.
Most importantly, if the pro gets rabies, it's not your problem.
Edit: Yeah, I know it a Do-It-Yourself site, but sometimes the right advice is "Don't Do-It-Yourself"
Russell Steen
  • 483
    Yeah, that's what I ended up doing although given the cost next time I may consider doing this myself. – Victor Jan 29 '11 at 16:48
    You probably saved yourself some cash in the long run. I once lived in an apartment where they used poison to kill some critters - they ended up having to take out all the drywall on the 2nd floor to remove the remains. That's a smell you really don't want in your dwelling. – chris Feb 05 '11 at 03:59
If they are only getting in from one spot, you can get a one-way door like this:
Picture of one-way critter gate
They can get out of the attic, but they won't be able to get back in.
Raccoon mating season is roughly Jan-Apr, so there shouldn't be any babies up there yet.
Michael
  • 3,776
I don't know where you are located, but here in Massachusetts it is illegal for anyone to live-trap a problem animal and move it for release on other public or private property. Unless you're able to prevent the raccoons from entering (before they have babies up there, otherwise they will find a way back in), you would have to capture it and either release it on site or have it killed. I think you as the property owner are allowed to do anything a licensed problem animal control (PAC) agent is allowed to do.
Also, raccoon hunting season ends January 31, but shooting them inside the attic is perhaps out of the question. :)
Vebjorn Ljosa
  • 9,575
  • 58
  • 86
I'd personally start by calling the local animal control office (it might be part of the local health department, depending on how your town/county/city/whatever government is organized)
They'd be able to tell you what's likely to be looking for new homes at this time of year in your area that fits the activity pattern, and what the laws are for trapping/killing/etc.
Joe
  • 7,256
  • 47
I had this problem in my house in Georgia with a number of animals, to solve I put my cat in the attic for a few hours a day for a week or so (usually when I was up there anyway). The cat never killed anything, (to my knowledge) but the scent of the cat drove the animals out for good. I have found this solution to be simple, cheap, and effective. It also works with dogs.
allindal
  • 2,044
We had a raccoon in the attic and hired a pest company to remove it. He sealed 3 entries and caged the 4th with a one way door. We got lucky the racoon didn't have a family in our attic. What they do in this case is get the adults out with the one way door and then go into the attic to fetch the babies. The important thing is to put the babies at the last exit point used by the racoon, if that means beside the one way door on the roof then that is what must be done.. if the raccoon cannot reunite with its babies it will tear your roof boards off to get back in. When it comes to roof work, I opt for the a pro.
BMNS
  • Also worth mentioning for raccoons : they can make you sick, and may require tearing out *all* of the insulation to clean the place. Before you try DIY, it would be worth reading up on the issue : http://www.humanesociety.org/animals/raccoons/tips/raccoon_latrines.html – Joe Aug 31 '18 at 00:46
