I would like to reduce the outside noise from inside my apartment. Outside, of my apartment is the hallway, and it can get noisy.
I was thinking about placing felt pads on my door to reduce the noise. My thinking is the sound vibrations from outside travel underneath the door and reach my room. My strategy is to place felt pads on the sides of my door, so the distance between the floor, the door ceiling and the door edges is minimal, meaning sound vibrations can't penetrate that place.
If you have other answers, lets hear them.
user21922
    Possible [duplicate](http://diy.stackexchange.com/questions/10574/what-would-be-the-best-way-to-reduce-low-frequency-noise-coming-from-neighbour-a?rq=1) – bib Jun 04 '14 at 14:17
    Are you sure the problem is the door? Apartments are notorious for thin walls... – keshlam Jun 04 '14 at 15:59
  • It's basic science. For sound to travel, it has to reach from part a to part b. If an area is blocked, sound can't possibly travel through it. – user21922 Jun 04 '14 at 16:04
    @user2192: sound can travel through solids, not just through air. For a serious noise nuisance people apply sound-dampening materials to walls, change their doors, add secondary doors etc. You can't prevent sound completely, only reduce it to a tolerable or normally imperceptible level. – RedGrittyBrick Jun 05 '14 at 09:57
  • What kind of noise is it? People, animals, stereos, vehicles, etc. – wallyk Aug 08 '14 at 19:23
Your options are limited being in an apartment, since you likely can't make very many permanent changes. I'll run through some ideas, though.
First, putting felt pads on the sides may help a little, but not for the reasons you think. They will do very little to dampen the vibrations -- you need mass or a dedicated damping agent for that. What the felt pads will help with is to reduce the mount of air flow through the door. Air flow is one of the absolute enemies of sound proofing. The more completely you can seal a door, the better it'll be. If you have the opportunity to attach an automatic door bottom (surface mount) and then some gaskets, then that'll go a long way towards quieting the noise.
Is your door hollow core? That is, does it sound hollow when you knock on it? If so, then you may look into replacing it with a solid core door. This can be done on a temporary basis as long as the hinges match up and you can simply pop out the old one and pop in the new one. A solid core door (especially a 1-3/4" thick one) will do a substantially better soundproofing job than a hollow core one. It does depend on you sealing it, though (see above) or else a lot of that benefit will disappear.
Beyond that... well, it really depends on how leeway you have towards making alternations to your apartment and how what your budget is. Attaching mass loaded vinyl to the walls and door would help, but would get pretty expensive very fast. Building an entirely separate interior wall would do a massive amount of help, but would absolutely cause noticeable marks when it was later removed. The flooring under the wall will certainly have to be re-done.
Kurt Granroth
  • 850
Do NOT attempt to make any modification to a common hallway door without at least consulting your local fire marshal. It is very likely that is it legally required to be fire rated, and your modifications very likely invalidate that rating. If there is a fire in your building, and investigation reveals that you modified your door, you could be held liable for damages caused by the fire.
Your fire marshal should also be able to help you determine if the current door meets fire safety requirements. If it does not, you should be able to get your landlord to install a replacement (which is likely to be significantly quieter than a non-fire rated door).
Zhentar
  • 1,212
  • In the United States the fire rating of a typical door between an apartment and the corridor will have little correlation to it's acoustical performance. The difference between the rated door and the unrated door is largely a matter of labelling. Solid core, metal, and composite door construction has a greater effect on acoustics. Anyway, if the frame isn't rated, then the assembly isn't, and in that case swapping out a non-rated for a rated door doesn't change code compliance or have much effect on life safety [the converse is of course not the case]. –  Aug 08 '14 at 17:23
    The construction of the door itself may not have substantially different acoustical performance, but smoke and draft control requires tighter sealing which can make a significant difference. – Zhentar Aug 08 '14 at 19:37
  • The cost for the manufacturer is not in quality control...poorly fit doors are unpopular with contractors, owners, and architects. The cost for the manufacturer is in the testing and certification process. Underwriter Laboratories underwrites its operations with fees for testing and certification (the same is true for Warnock-Hersey but it offers less opportunity for punning). To put it another way, acoustical quality is orthogonal to fire rating in the real world. –  Aug 08 '14 at 20:31
There are two types of noise in architectural acoustics: airborne and structurally transmitted. If people are screaming as they run down the hall, the screaming is mostly airborne noise and the running is mostly structurally transmitted noise.
Airborne noise can be attenuated by constructing walls, floors, ceilings, doors, etc. to absorb sound energy. Architectural components are rated by sound transmission class and in the United States, recent building codes have minimum requirements. However, airborne noise readily finds its way into a space via flanking paths.
Masking airborne noise is often a more practical strategy than trying to create a cone of silence. That is, it may seem counter-intuitive that placing a sound source in the quiet room, actually makes it more acoustically pleasant.
Structurally transmitted sound becomes more problematic particularly when the source is impact both because transmission paths are baked in to the construction and because the impacts can be irregular and at the longer travelling lower frequencies. Masking may have some effect, moving will probably have more.
Several ways to approach the problem come to mind:
  • Discourage noise makers: make changes to the environment so the noise makers want to leave: make the hallway temperature uncomfortable, use weird lighting, install atrocious art, provide a repellent scent, inject disagreeable noises, threatening animals, and/or arrange scary/dangerous passers-by.
  • Decrease the sound reaching your apartment: sound dampening materials on the door and wall. See this answer.
  • Make it harder to hear the noise: turn up your stereo, wear headphones, or install a noise generator.
wallyk
  • 12,319
