We just got an overly large (several hundred dollars over normal) electric bill from the city.
Being a bit of a diy I picked up an ammeter to to track down the reason. None of my circuits are clocking in over 2 amps in normal usage. I tried powering up everything in the house including all of the major appliances.
I only came up with a total of 22 amps, absolute max draw. US standard 110V.
I did the math but I wasn't able to crack our normal $150 / month (calculated out using the local kilowatt hour pricing).
What the heck is going on? Anything more for me to do before calling the electrician?
Edit:
The meter box is mounted to the side of the house, under a overhang.
When I used the ammeter I was working off the main hot line from the meter when I powered everything up.
I did see the other diy post.
We do have central air, howeverit was a lot cooler last month vs the same time last year. The usage shouldnt have spiked, at least that much.
The price per killowatt hour is comperable to last year as well.
We generally clock in at around 1200 to 1800 kilowatt hours. Last month was a bit over 2800.
We already tried (unsuccessfully) to lodge a complaint with the electric company.
The odd thing is the variance -$150 one month and near $1000 the next, with no noticible change in utilization patterns.
Tim Brigham
  • 494
  • Where's the meter? I only ask because a friend had a trailer with the drop to a pole and meter and buried cable to the service panel. The buried cable was nicked and the insulation finally broke down. – Fiasco Labs Jun 12 '14 at 01:12
    I suggest you monitor your meter on a daily basis and record the kwh it shows. You can then determine the kwh per day. That will give you better information that checking each circuit since it measures the whole house usage. Also, do you have an central AC? – getterdun Jun 12 '14 at 01:33
  • Duplicate? http://diy.stackexchange.com/questions/1713/how-best-can-i-discover-what-is-up-with-my-electrical-bill – Niall C. Jun 12 '14 at 01:37
  • You should include the total Kwh billed, and the rate at which it was billed, whether it was an actual reading or an estimate. A list of commonly used appliances/devices, and any usage changes within the billing period (e.g. started using A/C). Also, take a look at past bills to see if the rate changed (Don't forget to look at any service fees/charges, to see if any jumped up). – Tester101 Jun 12 '14 at 10:10
  • Your bill should have the starting and ending meter count. Check your previous bill to make sure its ending number matches this bills starting number. Also check the ending meter reading against your meter, typos happen all the time. – diceless Jun 14 '14 at 04:33
  • 22 amps @ 110 v is only 2.4 kW. Most central air conditioners use *at least* that much and you claim to have turned everything in the house on; are you sure you are measuring things properly? – Andon M. Coleman Jun 14 '14 at 23:27
  • @andon - yes, pretty sure. We retrofitted this house with high efficiency everything, except windows. – Tim Brigham Jun 15 '14 at 02:36
Are you sure your numbers are right? You say your kWh usage has about doubled, but your bill has increased 6x.
Anyway some utilities only do an actually meter read ever 2 or 3 months, then they estimate the bill for the other months. That can lead to extremely high bills if they've been underestimating and then they finally do an actual read and bill you for the extra that you've used. In theory the company is supposed to track your usage over time and get a good estimate but in my experience they can be wildly inaccurate. Your bill will tell you if the meter read is actual or estimated. Also note that some utilities increase rates in the summer when demand is high, so you may be suffering more if they just switched over to the summer rates.
If the problem is not just odd billing practices, you will need to dig a little deeper.
To help you narrow things down a little more, I would try to keep a log of your meter. E.g. try to write it down every day, or even twice a day to find out if your electric usage is constantly high or is intermittent. (Note that reading an old-fashioned dial meter is a little counter-intuitive, since each dial spins in opposite directions. See How to Read Your Electric Meter).
If you're really using 1000+ kWh extra each month, that's an average extra draw of 1.4 kW, which is pretty large. You should be able to see the meter spinning very quickly. Try shutting off circuits one by one to see what will slow the meter.
Hank
  • 14,003
  • 47
  • Electric companies work like the IRS. You start out in a small, affordable bracket, but then as your income (consumption) increases beyond a certain threshold that puts your future consumption into a higher tier. So it is not surprising that the cost grows non-linearly. – Andon M. Coleman Jun 14 '14 at 23:22
If you are willing to make a small intial investment, I would highly recommend buying an Efergy Elite / Hub.
This handy device clamps onto the mains line in your circuit breaker and measures power draw through inductance and sends it to a monitoring service over the internet for free. The device itself will run you $150 or more (if you have a 3-phase system you will usually need to buy an extra sensor because most kits only include 1-2 sensors).
Below is an actual live look at my own house:
  Screenshot
I have had the device long enough now to know that the large 9.0 kW spike at 4:30 PM is actually a combination of things - water heater, central AC and microwave. But if I did not know this, it would definitely be worth tracking down.
It is hard to be surprised by your bill at the end of the month when you can see your complete usage history from any web connected device anywhere in the world.
Thanks to everyone that responded. The insight has been tremendously useful.
While I am not 100 percent sure I believe I tracked down the culprit. Our drier had been taking longer to dry than normal the last couple months.
When I went to test it for usage I didnt verify that it was getting hot. It wasn't, which skewed my numbers. Turned out that I needed to replace the internal thermostats. A change in the duty cycle and length running of that device would explain a large shift in out bill, especially considering our lifestyle generates a lot of laundry.
Tim Brigham
  • 494
  • Please mark this as the answer – Joe Phillips Jun 15 '14 at 16:44
  • If you do a lot of laundry, the water heater may also factor in (assuming it is electrical). It is another device you cannot really "turn on" and test for changes in current, because it has a thermostat too. It will respond to the dip in temperature in its tank sometime *after* the washer uses a lot of the water. I bring this up, because as I track my own electrical usage regularly, the water heater is consistently the biggest offender when it comes to sudden spikes in current draw and they are always *delayed* by 10-15 minutes from the thing that caused them too. – Andon M. Coleman Jun 15 '14 at 19:38
  • @aandon - thanks. Thought about that. We have an inline gas water heater. – Tim Brigham Jun 16 '14 at 00:02
First off, you are not billed by the city, you are billed by the electric utility. Unless you're in Canada and then I'm not sure.
In cases like this you do not call an electrician, you call the utility that billed you. They take high bill complaints very seriously, at least around here they do (NY State). They will do what is necessary to find out what the problem is. If it does happen to be on your end they'll tell you so.
Speedy Petey
  • 16,388
  • 27
    In some locations you are billed by the city. My city owns the local electric utility ( they bought out the local one that was going out business ) – Brad Gilbert Jun 13 '14 at 03:30
  • Huh, never heard of that. Then again, the govt stepped into Amtrak and automakers, didn't it. – Speedy Petey Jun 13 '14 at 21:07
  • Here where I live, I am billed by the county for electricity. We have an electric coop that is owned by the county and leases electricity from several different sources. It is not that uncommon. – Andon M. Coleman Jun 14 '14 at 03:29
If you have a well, you could have a water leak, dripping faucet, or wiring problem with your well pump. Well pumps generally run on a fairly short cycle, and infrequently, but a relatively small leak can cause the pump to run significantly more.
TomG
  • 3,938
  • 25
  • 40
