I am taking a non bearing wall down that has electrical work in it, including a 3 way switch for a single light. I want to disconnect this switch so the other one works. How do I do this?
Asked
Active
Viewed 1,160 times
2It depends. Where is the power coming from, and where is the fixture? – Chris Cudmore Jun 12 '14 at 15:38
1Please post photographs of the wiring at each of the switches, and -- if you can trace the wiring -- a schematic of the circuit. – Niall C. Jun 12 '14 at 19:06
You will have to trace the wires. You can look at How exactly does a 3-way switch work?. You should replace the remaining 3 way with a regular single switch and wire it normally to the light fixture.
It depends. You might be lucky or not, depends on which way the wires go. Note that any any splices in wires must be accessible for future work.
Start with https://diy.stackexchange.com/a/4054/5960 and post some photos.
Define "abandon wires in the wall" please - one of the worst things one could do would be to leave hot wires in the wall. – The Evil Greebo Jun 15 '14 at 12:12
Abandoning a traveler in the wall is OK: he has access to both sides. There's not enough detail in the question to really outline the options. The OP has not come back, so there's little incentive to give a full answer. – Bryce Jun 16 '14 at 20:53
