I'm in a bind, with this valve taken out of the wall and the water supply turned off.
It looks like these pieces are all intact, nothing broken. The valve stem screws into what I would call the valve seat, but the valve seat doesn't have anything to keep it from spinning freely, so I am unable to see how the valve works reliably.
The stem is quite long, and its not easy to look inside the valve unit inside the wall. So I can't add anything to the description about that.
Underneath the upper end of the valve (the part that holds everything in place and is visible in the picture at the opposite end from the valve seat), there was a fiber washer. I was thinking it provided pressure on the valve seat to keep it from spinning, but the original washer wash not very elastic at all.
Update
I was able put the valve back together with some guess work by putting some stem packing as shown in the photo below:
This didn't assure me that I had it properly put together, but it removed the urgency, as I now have a working valve.
In th mean time, I learned that this valve is probably the American Standard Version II Tub Shower Stem of the Re-Nu style. I found this on a restoration plumbing website. These are described as from Art Deco fixtures from the 1930s to 1950s, which puts it in the right period.
The restoration site supplies reproductions with a modification at the end of what I have been calling the "seat". They call it the "barrel". The modified barrel has a rubber o-ring at the end (on the outside).
I am not sure about stem packing, but repair kits show a part that may be for stem packing. I think this would be necessary, and I'm guessing the original stem packing disintegrated over many years.
If anyone can explain more fully and correctly how this valve should be repaired, I'll accept the answer.
The Evil Greebo
  • 25,821
  • 124
Jim
  • 444
  • It does not look at all familiar. What country is it in? Do you have good access to the other side of the wall—in case the whole valve body needs replacement? – wallyk Jul 13 '14 at 20:08
  • This is a US installation. I'd rather not have to replace it. It doesn't look broken, so I'd rather understand how it works. But the other side of the wall is accessible in a finished room. I was able to get it together with a big O-ring as a compression washer, but it still dripped. I took it apart and haven't been able to repeat that feat. It's odd that there is no valve stem seal, either, and some of the drip is coming out around the stem. – Jim Jul 13 '14 at 20:15
  • I think you are right about the purpose of the fiber washer. It should not be very elastic, instead it should provide enough pressure to make the chamfered/clean edge of the 'seat' assembly seal in its housing when you tighten the upper end of the valve. Once that interface is well sealed, then the rest of the valve works as usual. Which leak are you trying to solve? Through the normal pathway when off? Or around the stem during operation? – Dave X Aug 04 '14 at 16:09
In one hole, and if the seat is open, out the other.
If it doesn't seal well even though you have replace the 'washer' at the end of the stem, a seat grinder will smooth the seat out. Go find a 75 year old plumber, he will have one.
An alternative valve stem packing was a rope like material - the neoprene washers you added are a substantial upgrade. I haven't re-seated and repacked one of these in at least 15 years but your assembly looks good.
