We were trying to replace old switch plate covers at our new house when we came across one that is a type I've never seen before. It's a light switch cover that looks like an ordinary cover except for a small bulge above the switch that's maybe an inch across and half an inch tall. It's kind of an elongated pyramid shape. Removing the cover reveals two wires coming from the box (one from the top right, one from the bottom left) that appear to be soldered behind the lump. There appears to be a small piece of what looks like PCB board material, but doesn't show any features aside from the points where the two wires are attached.
Does anybody have any idea what this is? I don't want to just yank the wires out (they are attached to screw terminals in the box) without knowing what they are supposed to do.
The house was build in the early 20th century, so the plate could be really old.
Matt Burland
  • 283
    My guess is that it's an illuminated cover, which no longer works. Turn power off, disconnect the two wires to the cover, and replace with a regular cover. While you're at it, you might as well replace the switch. – Chris Cudmore Aug 07 '14 at 13:18
  • @ChrisCudmore: That sounds possible. It doesn't have any kind of clear window which would make that obvious, but I don't think all illuminated switches do. – Matt Burland Aug 07 '14 at 13:29
    Some used to just glow behind the plastic. – Chris Cudmore Aug 07 '14 at 13:36
  • Searching for illuminated switch plate, I came across [this](http://www.homeownershub.com/maintenance/illuminated-wall-switch-plate-110785-.htm) on another site that sounds like it might be the same thing. Possibly mystery solved unless anybody else has another idea. – Matt Burland Aug 07 '14 at 13:44
  • @ChrisCudmore: Turns out, you were correct (if you want to write an answer, I'll accept it). I went back to the house last night and examined it again and found a label on the back that said something to the effect of "GUARANTEED RENEWAL SERVICE. Should **light mechanism** ever burn out...send it back along with 35 cents for a replacement". Needless to say, I'm not going to bother sending it back! If I'd noticed that before, I probably would have put 2 and 2 together. – Matt Burland Aug 08 '14 at 13:38
  • I don't know - might be fun to see what happens if you can find the company or its successor and send them the cover and 35 cents ;-) – Ecnerwal Aug 09 '14 at 00:58
Commment converted to answer.
Chris Cudmore
  • 14,089
  • 59
  • +1 for swapping out that fire hazard of a switch. If it has a slotted screw it's about time to make it go away. – Mazura Sep 17 '14 at 03:14
