We recently purchased a new washer and dryer set. It's a High Efficiency front loader washer with the high speed spin cycles.
It's causing us grief. It vibrates like crazy. To the point where it's walking across the floor and you can feel it throughout much of the first floor.
I've 'tuned' the feet to make sure it's perfectly level, and it helps, but is not a cure-all.
There seems to be a lot of chatter online and theories, though I have yet to find anything definitive (maybe I'm adding to the chatter...)
Questions:
  • is it true these really should only be purchased if used on concrete slabs? Seems that's a common statement about these HE washers.
  • is there a tried-and-true way to beef up the floor? Seems that one solution is to rip out the hardwood and then glue-and-screw two layers of high quality sub-floor products together. Then add lots of cross-bracing to the joists underneath. However, I still read that this doesn't fix all situations. And given how much work that'd be, I'd like to be a bit more confident in the solution before beginning.
  • we have a plastic 'leak pan' underneath that the feet sit on. Should I omit this? This is obviously an easy thing to try so will probably give it a go--though we do end up losing the (albeit small) benefit of having the leak pan.
  • or should I just give up and see if Home Depot will allow a return and swap it out for a lower efficiency top-loader?
Note I have researched the rubber pads. However, my own experience with them previously (on a top loader) and feedback from plenty of people online is that they really don't do much, if anything.
DA01
  • 24,235
  • 27
  • 76
  • 146
    I've never liked laundry rooms anywhere other than basements. They shake the whole house, and leaks are a mess. You'll never stop the vibrations, unless you completely isolate the machine from the floor, or the floor from the rest of the house. – Tester101 Aug 25 '14 at 02:04
  • I'd start by moving the washer off the leak pan to increase the friction between the washer and the floor. Might also provide better leveling. For a few bucks, I might even look at a door mat to both protect the wood floor and to dampen impact noise. Or, if you return it, consider looking at noise ratings and remember that +3db is twice as loud and -3db is half as loud. –  Aug 25 '14 at 02:14
  • @Tester101 I miss basements. Alas, no basement here. Best we could do is remodel the garage, but that's a task I'm not sure I'm ready to tackle. Looks like we may have to give up and return it. – DA01 Aug 25 '14 at 02:14
  • @benrudgers I'm not so concerned about noise, but the movement. It's a pretty violent shaking. Can't be good for the house nor the washer. Will try it without the drain pan tonight. – DA01 Aug 25 '14 at 02:15
  • I've seen some designs to try and reduce the transfer of vibrations caused by earthquakes into buildings. A base that used some of those techniques might be helpful, though might be not financially viable to manufacture. – Tester101 Aug 25 '14 at 02:42
  • Recoil reduction techniques used in firearms; notably those used in the [AA-12](http://en.m.wikipedia.org/wiki/Atchisson_Assault_Shotgun), might also be worth reading about. Though again, putting this technology into a washer base might not be worth the cost. – Tester101 Aug 25 '14 at 02:53
  • Yea, I'm not engineering a new product here. :) Looks like I'm heading to the return lane at Home Depot. – DA01 Aug 25 '14 at 02:57
  • @DA01 The acoustics are likely to be a good proxy for vibration. –  Aug 25 '14 at 04:37
  • Posted for @ColonelAngus: complete novice here but I'm curious why none of the proposed solutions go at it from the approach of attaching the appliance securely to the floor or wall by some sort of bracket or epoxy? I'm just not convinced that by making it a less stable footing that your not exacerbating the jiggling. I understand the energy has to go somewhere but wouldn't it make sense to bolt the washer to the floor through neoprene, rubber, whatever...? – Daniel Griscom Jan 04 '16 at 12:28
    complete novice here but I'm curious why none of the proposed solutions go at it from the approach of attaching the appliance securely to the floor or wall by some sort of bracket or epoxy? I'm just not convinced that by making it a less stable footing that your not exacerbating the jiggling. I understand the energy has to go somewhere but wouldn't it make sense to bolt the washer to the floor through neoprene, rubber, whatever...? –  Jan 04 '16 at 01:10
After spending several hours researching, there still appears to be little consensus on this topic. But here is a summary of potential solutions.
The Problem
But first, the problem: the issue with High Efficiency Front loaders is that the vibrations are vertical. The drum spins horizontally so the vibration is all in an up-and-down motion. It's also incredibly high speed. The problem is that wood framed houses aren't designed to withstand the vertical vibrations of these newer washers that well. a HE top loader, while also fast, transfers the vibrations horizontally, which the floor framing of a house is better suited to handle.
The List of Possible Remedies
Get a top-loader instead.
A traditional top loader (agitator) spins, but not nearly at the same speed as a front loader. It also does it horizontally so doesn't transfer nearly the vibrations that a HE FL will.
The catch is that these are harder to find and more and more top loaders are now HE top loaders. Instead of an agitator, it uses jets of water. Reviews of HE top loaders seem to be mixed. However, there seems to be consensus that they don't clean quite as well as front loaders (a con) but that they also don't vibrate as violently as a front loader (a pro if vibration is an issue in your house).
Only put HE Front Loader washers on top of concrete slabs.
10 years ago, this was supposedly the only option. Apparently technology has improved to allow these to be installed on wood framing--however many professionals still do not recommend installing it on a second floor (as second floors tend to not be built to handle the same loads as the first floor).
Make sure the washer's feet are all level.
This is the easiest/first thing to check. I thought mine were but on careful examination I was able to improve things further by adjusting the feet. The easiest way to check this is to reach to the back of each rear corner and try shaking it towards the opposite front corner. You're are testing the diagonals to figure out if one of the corners needs to be raised. I had one ever-so-slightly out and adjusting it helped quite a bit (I suggest grabbing the rear corner is that is likely sheet metal and rigid rather than the front, which is often plastic and hard to 'feel' for wobble).
Move the appliance towards a wall/corner
The closer to a corner, the more rigid the structure may be (might be closer to a support beam, walls may add lateral rigity, etc.) I moved ours closer to the corner of the laundry closet and it seems to have helped.
Use rubber vibration feet/pads/matts
There are dozens upon dozens of companies selling anti-vibration feet. A majority of people claim that these help, but a strong majority claim it makes things worse. My (non-physics-expert-mind's) opinion is that when they do work, though you may reduce the transfer of vibration to the structure, you are likely increasing the total amount of vibration the appliance, itself, now has to absorb (reducing its lifespan).
Use pool noodles on the sides
A common youtube/facebook suggestion is to take the pool noodle foam floaties and cram one between each side of the washer. This will only work, of course, if your washer sits close enough to the wall on one side and the dryer on the other. I haven't tried this yet. My (again, non-physics-expert-mind's) theory is that this spreads the vibration load out to more planes/points of contact.
Reinforce the floor
I see many suggestions of this, but not necessarily any first-hand reports as to how succesful it is. I'm guessing it's just because it's likely a pain to deal with. The suggestions are to tear out the floor and then glue-and-screw two layers of subfloor together with a tight screw schedule. The subfloor being plywood or dedicated subfloor products.
In addition, add blocking to the joists underneath and, in extreme cases, ass a support beam/post directly under the laundry area.
My conclusion
As previously mentioned, double checking the level of the feet has helped considerably. And while I'm happy with the improvements, it still vibrates hard enough on its final spin cycle that you physically feel uncomfortable standing in front of it.
I'm now narrowing it down to two options:
  1. Try a HE Top Loader. The problem is that I really do like the front loader's performance. It uses less water and cleans better that the top loaders apparently due. And because of the extreme spin cycle, we save a lot of energy with the dryer. As such, I think I'm going to...
  2. ...reinforce the floor. Right now the sub floor is chipboard with hardwood flooring. Neither is all that sturdy. I'm going to take out the hardwood (bonus is that we can use this to patch parts of the kitchen later) and possibly the existing subfloor if it's not too difficult. I'm then going to glue-and-screw down one or two layers of 3/4" plywood (I may use maple ply for the top one and apply poly on top to make it a 'finished' surface). I'm also going to add blocking between the joists.
What we ultimately ended up doing
I bought a 4x6 and created a beam in the crawlspace under the washer/dryer area with two lolly columns. Alas, that still didn't seem to remedy the situation.
So, we gave up. I hired an electrician to wire up a space in the garage and I plumbed a new drain line and vent stack and we moved the entire thing into the garage onto concrete.
And things are good now. I do believe that these HE front loaders are truly only really designed for placing on concrete slabs.
The plus side is now we don't have to try and do laundry in a hallway closet.
DA01
  • 24,235
  • 27
  • 76
  • 146
    Excellent! Thanks for summarizing your research into this helpful answer. I agree with your solution #2: in my mind, a good HE front loader is worth the pain :) – bitsmack Aug 25 '14 at 17:08
  • Maybe mounting the dryer on top helps dampen the vibrations? – gbronner Sep 05 '14 at 17:42
  • I'd actually prefer them stacked. Alas, there's no room for that in our situation (which is essentially a house that was designed without any thought put towards where the washer/dryer would be so they're now in an under-stairs closet) – DA01 Sep 05 '14 at 17:44
  • I'm having a similar problem with my front loader. What method did you end up using and is it working? –  Sep 07 '15 at 22:40
  • @TonyBrito I just updated my answer with a final update as to what we ended up doing (essentially: giving up and moving it to a concrete pad) – DA01 Sep 08 '15 at 01:34
Here's a simpler solution: Many HE washers have a special 'tuning' setting, where you can input the floor type. The base level assumes a very hard and non-resiliant floor, but (at least on mine), you can change it to a hardwood floor setting.
gbronner
  • 5,148
  • 44
    That's interesting. It doesn't appear that's an option on the LG I have, though. – DA01 Sep 04 '14 at 06:56
  • Check... it is a really obscure option that I only found by reading the manual on my GE washer. It also might work better for me because I have my dryer mounted on top (using optional brackets), and the extra mass may be helping to damp the vibrations – gbronner Sep 05 '14 at 17:41
  • Ours is an LG an the manual actually suggests reinforcing the floor. – DA01 Sep 05 '14 at 17:43
I live in a condo situation where relocating the laundry machines is impractical. Leveling and distributing laundry mass in the machine did not help enough.
There are 30 pound (~13.6 kg) rubber mats (now ~$105) that are advertised to address walking and vibration that work reasonably well. Mine has a handle and beveled edge, but it's basically a massive rubber mat.
I have personally tried:
  1. rubber pucks only: I would not recommend. This was my starting point from the prior occupants.
  2. rubber mat + plywood + rubber pucks: This is the solution suggested in reviews for the rubber mats. It does a good job of reducing vibration, but I had trouble with the pucks walking across the plywood.
  3. rubber mat + plywood + rubber mat: I think this is an acceptable solution. There is still a low frequency vibration from the washer that transfers to the building when the washer drum (de)accelerates quickly. This lasts for a few seconds and happens ~6? times per load. High frequency vibration is greatly reduced relative to the pucks only, but not totally eliminated.
Sliding mats or plywood under the washer is a strong-two-person job, so I did not bother trying the rubber mat by itself based on its reviews and the marginal additional cost of plywood and the inconvenience of getting a strong friend to help.
These solutions do not address vibration of the washing machine itself, only transfer of that vibration into the building.
Starting from scratch, I would avoid a front end washer on upper wood frame floors, but if you have this situation, I recommend the rubber mat.
mattm
  • 111
  • Makes sense to me. "Shock absorber" between machine and house, for the same reasons resilient mounts are used for car engines. Having a large mass between machine and house would also tend to filter out higher frequencies, which may be why drier on top of washer works for some folks. If floor loading would take it, a thick concrete pad might be worth trying for the latter effect. – keshlam Aug 27 '23 at 16:11
