I'm trying to make myself a wooden CNC machine. I haven't started on the woodworking yet, as I'm still planning on the easiest way I can construct the machine (newbie here).
I'm planning to use 1' x 4' wood as the frame for the X-axis, since that's the only material I can get my hands on. How do I connect them together at 90 degrees while maintaining a solid connection? I don't have any fancy tools; at best I can get a hand drill, a jigsaw and some vices.
enter image description here This is just the simplified view of the X-axis frame. It's just a normal rectangular frame..
Sodrohu
  • 33
    Are you sure you can get enough accuracy with a wooden frame? CNCs aren't particularly tolerant of *any* sort of axis deflection. – Comintern Oct 02 '14 at 03:22
  • @Comintern Well, wood is the best/most budget-friendly material I can get access to right now, so it'll have to. Besides, I've seen some CNC builds on the 'net using plywood/MDF/other wood-derived materials so it's probably good. – Sodrohu Oct 02 '14 at 03:41
    Just curious more than anything. I've been looking into doing a DIY CNC router myself and ran across a bunch of warnings about deflection on the axis rails. – Comintern Oct 02 '14 at 03:43
How do I connect [1x4 wood] together at 90 degrees while maintaining a solid connection?
If you can obtain a hand-saw (e.g. tenon-saw/back-saw), some sandpaper and some wood glue, you can make lap-joints. I find they are the easiest way for me to make rigid joints in wood.
To join wood the other way, for a strong joint I'd try a simple finger joint (box joint)
I find jigsaws are a good way to make wobbly uneven cuts in sheets of wood. Maybe that's just me. Chewing through wood with your bare teeth is not much worse. A back-saw and a miter-box might be more useful to you if you can obtain them.
RedGrittyBrick
  • 24,201
  • 47
  • I've added a pic of the frame for your reference. – Sodrohu Oct 02 '14 at 09:54
    @Sodrohu: I'd use a lap joint. The wood in your sketch doesn't look like 1x4 in cross section, is that the frame size in feet? what are the actual dimensions of the wood you intend to join? – RedGrittyBrick Oct 02 '14 at 13:18
  • Oh, I forgot to put the dimensions in...it's still 1 x 4. Hold on let me fix that. – Sodrohu Oct 02 '14 at 14:44
  • For the finger joint, how should I keep them in place? Is wood glue enough, or do I still need to use wood screws? – Sodrohu Oct 02 '14 at 15:49
  • @Sodrohu: The glue provides sufficient rigidity and strength as long as the joint is reasonably close-fitting. If I was concerned about strength I'd reinforce the inside of the joint. You can probably use screws to hold the joint tightly together while the glue dries if you don't have clamps. – RedGrittyBrick Oct 02 '14 at 16:08
I would just drill pilot holes and screw it together, you don't need to do fancy cuts in the wood. If you need extra stability, put in a diagonal (diagonal cuts all the way across a board are much easier than notching). I would put in a small diagonal brace on each corner, although it would be easier to just use a large one across the whole frame.
I built a fairly nice CNC out of steel and aluminum and the framing members were butted togther and bolted to corner plates (which also added some diagonal support). The thing weights almost 200 pounds and I can lean it up on one corner of the X-axis frame and it doesn't budge at all. Butt joints don't look very nice, but they are easy and work just fine if you brace them properly.
While you could make your machine out of 1x4s and a dremel tool, I would at least use solid sheets of MDF and 2x4s or aluminum square tubes. Wood is cheap; most of your budget will be on your linear slides, screws/belts, motors, and controller(s) and it just isn't worth it to greatly limit the performance of your whole machine by skimping on what will end up being such a small part of your overall budget
Which way is the 90 degrees connection going? ie are the pieces of wood in the same plane (a flat joint)?
If they are, you could use a use a half-lap joint (or perhaps a mitre).
Or are the pieces of wood in different planes?
This gives you various options for the joint, for example:
  • Rebated joint.
  • Mitre
  • Biscuit joint (possibly also with a mitre)
  • Box / finger joints
  • Dovetails
  • Mortice & tenon
In this case, you might even be best with a fillet across the corner for reinforcing the joint to give maximum stiffness.
Hard to say for sure without seeing your machine design intentions.
John
  • 2,410
An easy yet secure method would be to use a pocket-hole jig, like a Kreg jig. Go to their website and watch the explanational video. There are also Youtube videos explaining how you can make your own jig if you don't have the money for a Kreg or other brand.
