I just installed a new sink and faucet and get really bad water hammer when I run the faucet. I never had this trouble before. I made sure the water supplies from the copper to the faucet is as short as possible. How can I fix it?
Asked
Active
Viewed 1,984 times
1Have you looked at [How to fix “water hammer” in your house?](http://diy.stackexchange.com/questions/1749/how-to-fix-water-hammer-in-your-house) – allindal Mar 12 '11 at 20:57
1Thank you for your response, yes I have, my problem is localized to a faucet and only happens while water is on, not when it is shut off. – Mar 12 '11 at 21:40
With the water running, and presumably making the noise, put your hands on the copper pipe - can you feel the vibrations? Does it go away if you hold the pipe? (Be careful of the hot water pipe - it can get, well, hot)
It could be that the pipe is simply loose.
chris
- 3,271
- 1
- 23
- 20
What you have a 'water whistle' not 'water hammer'. One of the supply valves to your sink isn't fully open, creating a pocket of low pressure behind the valve that is oscillating hammer like effect. Fully open your supply valves and the problem should go away.
virtualxtc
- 2,537
- 9
- 28
- 46
