I am looking to buy a remotely controlled light switch. What options are there? I do not want companies or brands or models or whatever. I am looking to buy light switches from which I can build my own personal controlling system. What types exist? Which are wired and which are wireless?
EDIT, with more info on what I mean When I said I don't want brands or models I mean I do not people to my shopping. If you have an answer that also includes a brand or model it's ok. I put that part in my question so as to prevent brand-only answers. Now for the usage. For now I am trying to create a wall panel that will control the lights of my house, either wirelessly or wired, I do not know. In the future it might lead to home automation. But for now I just need to control them remotely. I just do not know from where to start.
Kate Gregory
  • 1,417
John Demetriou
  • 360
  • What type of "control system" are you building? If you do not want brands or models what info are you looking for?? Is this for home automation or something else? – Speedy Petey Nov 26 '14 at 12:31
  • @SpeedyPetey edited my question with more info – John Demetriou Nov 26 '14 at 12:34
  • Quick tip: If you go with the X-10 protocol (control signals transmitted through the power lines themselves), which was one of the earliest solutions to gain widespread support, be aware that the X-10 company themselves are NOT the best manufacturer thereof. Their build quality is adequate but not great, and their competetors generally offer improved function. I've got an X-10 (brand) kit that I've been playing around with as "cheap and cheerful", but it isn't what I'd install for longterm use. – keshlam Nov 26 '14 at 14:56
  • Also, watch out for the fact that most fluorescents really don't like dimmers... and many of these remote switches can dim. That's actually the main thing holding me back; I want to replace more of my CFLs with dimmable LED bulbs before putting them under remote control. Pity CFLs last so long... – keshlam Nov 26 '14 at 14:58
  • Tip: Don't do X10. It's cheap, but that's literally the only thing going for it. X10 is really, really awful (as in, random noise is mistaken for the "All on" command on a monthly basis, signals get lost, multiple commands noticeably take several seconds to send). Insteon is decent (so long as you use dual-band), reasonably cheap, and the gear looks nice. Z-Wave has more manufacturers supporting it, the gear is starting to look nicer than it used to, and apparently it works quite well. UPB looks nice (programming flexibility puts all others to shame) but is a bit more niche. – gregmac Nov 26 '14 at 15:23
  • Also, possibly dupes: [What are the pros and cons of different types of smart switches (that are on the US market) ?](http://diy.stackexchange.com/q/384/157), [What is the most common home automation technology?](http://diy.stackexchange.com/q/21356/157), [What are some scalable, affordable home automation options?](http://diy.stackexchange.com/q/2984/157) – gregmac Nov 26 '14 at 15:26
  • I'll add that if you do decide to go the "hub" route and are looking for full control with phone/internet integration, I do not recommend Insteon. I have had good luck with them in certain applications, but in my own home and others I have worked on I have had many issues of dropping communications, losing schedules, and just basically poor reliability. – Speedy Petey Nov 26 '14 at 15:57
    What problem are you trying to solve? A panel that controls all the lights in the house is one possible solution, but there may be others. The others can only be seen by focusing on the problem rather than a construction project. –  Nov 26 '14 at 16:40
I've seen every type of "home automation light switch" system, but they all require some sort of "hub" by a company. Some communicate wirelessly and others do not. They also have varying levels of security.
Random home switch by company that requires a hub
If you are still against a hub, there is one more option you have:
Solid State Relay
Solid state relays. You can wire them inline before all your lights, then put an arduino with it. Example: http://www.instructables.com/id/Arduino-Controlled-Relay-Box/?ALLSTEPS
However you will not have physical switches any more- you will need to replace them all with some sort of momentary switch which ties into the arduino and relays.
DarthCaniac
  • 1,368
    How is an Arduino not a "hub" in the way you described? Single centralized device, bridges gap between protocols, and relays control signals... – gregmac Nov 26 '14 at 15:18
  • @gregmac: Good point! I think of it as not a hub since you have so much control over it, as opposed to a pre-made home automation hub which you have to play by their rules – DarthCaniac Nov 28 '14 at 15:22
  • That's definitely a concern, and something that should be considered when buying any of these types of devices. Good questions I would ask are: Does it rely on a 'cloud' service? What happens if your internet connection is down? What happens if the company shuts down their servers? Is there any type of SDK or API that can be used to interact with it? Is there an active user community? Is there an ecosystem of plugins/companies around this that add value? – gregmac Nov 28 '14 at 20:35
Your kind of looking at brands as there is no universal protocol.
The cheapest is probably x-10 which uses a very unreliable signal thru the house wiring.
Beyond that google around insteon vs. zigbee vs. z-wave vs. upb for a flavor of option$
fred
