I recently moved to my first home (with a modest yard). The previous owners left behind about 20 cinder blocks. I'd like to build something constructive with them in lieu of discarding them. Any suggestions?
I was thinking about a BBQ smoker. Is that possible with cinder blocks?
Any ideas or useful links will be much appreciated.
Aarthi
  • 1,143
Gingi
  • 131
  • [Shelves](http://diy.stackexchange.com/questions/5495/tips-on-making-classic-brick-and-plywood-shelves)? – Tester101 Apr 08 '11 at 16:10
Depending on your location, build a planter. This included the base and the wall surrounding it. You could do a traditional rectangle or something modern like these...
http://pocketgrow.com/blog/wp-content/uploads/HLIC/8ba626a0e2155abfa3bd213bdbba202e.jpg
Glorfindel
  • 1,173
allindal
  • 2,044
You could build an outdoor fire pit. Be sure to check with your local fire regulations first; depending on your location, the fire pit might not be allowed, or there might be restrictions on when you are allowed to use it.
Steven
  • 27,594
  • 53
  • 88
Danny T.
  • 1,026
You could make a small seating area with benches made from cinder blocks and blocks for side tables; it'll be nicer if you top the cinder block structures with something comfortable to sit on.
A quick web search turned up:
  1. cinder block furniture projects,
  2. hand make outdoor furniture
A smoker might work, but the blocks are very porous; you're going to build up smoke in the walls, and you're going to have a hell of a time sealing the gaps between.
Alex Feinman
  • 3,502
  • Thanks for all that useful info. I am finding conflicting info about the use of cinder blocks for a smoker; what you're saying makes sense. There's something compellingly postindustrial about using the cinder blocks for indoor furniture. Will have to float that idea with the wifey. :) – Gingi Apr 08 '11 at 17:21
