I'm building a non-structural wall in my basement. I'm using Pressure-treated lumber on top of a foam sill gasket to protect from any moisture. How many tapcons should be used per 8-foot length to ensure long lasting stability?
Randyaa
    Not sure but some folks say 42 is the answer to everything. – Michael Karas Feb 04 '15 at 14:37
  • I enjoy the humor but I'm looking for a helpful answer ;) – Randyaa Feb 04 '15 at 14:40
    Have you considered using a [powder actuated tool](http://en.wikipedia.org/wiki/Powder-actuated_tool), to drive fasteners into the floor. You can pick up a cheap 0.22 caliber single shot Ramset for ~$25.00. Load the nail, load the charge, place the tool, give it a whack with the hammer, done. – Tester101 Feb 04 '15 at 16:23
  • I considered it and ultimately decided on the Tapcons. – Randyaa Feb 04 '15 at 16:28
    You must like drilling holes in concrete. – Tester101 Feb 04 '15 at 16:33
  • I agree with @Tester101 - In almost all cases tapcons suck for this. Popping in nails is just as effective with 10x less work/time. Also drilling tapcons into concrete is hell on your tools. – DMoore Feb 04 '15 at 16:40
  • I tried doing tapcons without a rotohammer once, I'll only do that mistake once. – diceless Feb 04 '15 at 18:59
  • I was only able to find a fastener schedule for sole plates attached to joists or blocking, which calls for 16d equivalent fasteners every 16" o.c.. No luck finding any "official" fastener schedule for non-bearing walls attached to concrete. It's either not covered in code, or not easily located within the code. Contacting the local building department, might be your best option. – Tester101 Feb 04 '15 at 19:10
6 Answers6
I'd use 3 good ones in an 8 foot run; more if they don't feel solid. (Since it's not structural, all you're really trying to do is hold the wall to the floor and resist any after-the-fact warp/twist issues.)
Aloysius Defenestrate
  • 20,214
  • 54
  • This is about what I thought was reasonable but I was worried about shear strength. Is 3 appropriate to secure the wall with occasional lateral force? This will be living space and there are children. – Randyaa Feb 04 '15 at 16:30
  • @Randyaa: Will the children be driving tractors in the room? Will the be using a wrecking ball? If not, then three fasteners are plenty. – wallyk Feb 04 '15 at 19:52
  • Thanks for the help. 3 seems to be the way to go and my worries were unfounded. – Randyaa Feb 04 '15 at 20:15
  • It's all about how they feel going in. If I didn't like it, it gets another one right next to it. – Mazura Feb 05 '15 at 02:28
The sill or bottom plate you are securing to the concrete will likely not take any impact itself, but will have to accept impacts from studs attached to it.
This question shows a typical 2x4 can expect to hold well over 300 pounds of evenly distributed force over a 6 foot span with no issues. It will handle sudden impacts of significantly greater magnitude before failing. So you can expect the wood to be fine with only 3 positions along it secured to the floor.
A 3/16 tapcon, embedded in normal concrete one inch deep has a sheer strength of over 700 pounds.
So as far as "long lasting stability" three tapcons per 8 foot length is probably still overkill.
You might want to secure it more frequently for purposes of vibration/noise reduction, or if your concrete is suspect, but beyond that you're wasting fasteners, drill bits, and time.
Adam Davis
  • 3,313
  • 37
If you've prebuilt the wall, one per stud bay will provide sufficient clamping. (6 total for 16inch stud spacing)
If you are stick-building in place , I like two at each end (staggered by an inch and countersunk). Then 3 more at 2 ft intervals. (7 total for 16inch stud spacing)
I use the 1/4 inch vs the 3/16 version for more strength. The 3 1/2 x 1/4 are good for this task.
HerrBag
  • 12,104
  • 37
    Always use 1/4", 3/16 strip or snap half the time. – Mazura Feb 05 '15 at 02:21
    Putting "two at each end (staggered by an inch and countersunk)" is problematic for a couple of reasons. First, the minimum recommended distance between any two anchors is 10x the anchor diameter (2 1/2 inches for 1/4 inch anchors), at the risk of weakening the holding strength of each. See [this page](https://www.confast.com/articles/rules-for-fastening-to-concrete.aspx). Second, countersinking them is not recommended either since it weakens the connection by reducing the plate thickness. See [this page](http://www.abag.ca.gov/bayarea/eqmaps/fixit/ch4/sld035.htm). – kkahl Oct 04 '16 at 09:14
I'm doing something similar, except I'm using powder-actuated charges to push a nail in instead of a Tapcon scheme.
Same situation in the basement, too... non-load-bearing regular partition walls, with kids running around and all that.
See my earlier question here: Is there a recommended distance between fasteners on sole plates?
In short, I'm using 3 fasteners, though that looks to be more than what's necessary.
alt
  • 1,807
  • 25
  • 38
My rule of thumb is one at each end, and then every other stud. Every other stud may be overkill, but it's easier to overdue it a little than under do it and have to repair the job later. Structural fasteners around the top and bottom plates tends to be done as close to a stud as possible, to leave lots of room for utilities that are being drilled through. You won't have this on your concrete floor, but it doesn't hurt to stay close to the stud (but not so close that you can't fit your drill in).
BMitch
  • 42,687
  • 197
I have been framing basement walls for years. I use 3 tapcon anchors per 8 ft run. Pre drill the treated base plate for the anchors, counter sink them a 1/4 inch, then lay a heavy bead of construction adhesive under the plate. Use a good concrete bit to drill the anchor holes. They should be at least an inch deep. I nail up my framing on the basement floor and then stand it up on the base plate and nail in place. The ram set method may be somewhat quicker but leaves a tail sticking up.
