We are getting ready to pour a new concrete slab over top of an old slab where a house was demolished. The old slab is 4-6 inches thick, and the new slab will be 3-4 inches thick. We would like to run PEX lines for a hydronic radiant heat system in the new slab.
From the research I have done, everyone says to use insulation under the slab to prevent the heat from going into the ground instead of into the house. I am wondering how critical that is and how much it will affect the efficiency of our system since we don't have the option of putting insulation under the slab. Should we abandon the radiant heat idea?
Any advice is appreciated!
BWDesign
  • 295
If you want to do radiant infloor heating you will need to insulate under the slab. If you don't you will constantly be rejecting heat to the ground underneath the slab, and it will suck excess heat out of the system. If your not going to insulate beneath the slab, abandon the idea of radiant infloor.
Your also going to have to use HE Pex for radiant infloor. Standard waterline Pex is not allowed for hydronic heating systems.
Mnc123
  • 937
  • Thanks for the advice. I was wondering if the slab underneath might act as an insulator against the ground. There will be about 1.5 inches of concrete above the pipes, but 6-8 inches beneath it. I would think that would allow the heat to escape upward more easily. Also, does heating the ground under the house really cause that much heat loss? Wouldn't the warmth still eventually rise back into the house? – BWDesign Feb 22 '15 at 22:39
  • You will have a substantial amount of heat loss in my experience. Especially if you have a high water table, the system will never maintain a decent slab temperature. Every system i have ever worked on but one was insulated. The single house that i went for a service call to had the ground loops installed by the contractor. The system never worked from day one, however it was operating as it should, something was just sucking so much excess heat from the floor. I suspected that the slab was not insulated, and later found out i was right by pictures the homeowner had. – Mnc123 Feb 22 '15 at 23:35
  • Either insulate under the slab or scrap the idea. Its quite costly to finish a house and realize that the infloor heating is not working. – Mnc123 Feb 22 '15 at 23:38
  • Ok and phooey :P Thanks for the advice! I guess we will stick with a geothermal forced air system. – BWDesign Feb 23 '15 at 11:37
  • Skip the geothermal and just use air-to-air heat pumps. Geothermal will never pay for itself, and modern Japanese heat pumps are actually almost as efficient as geothermal systems. It's amazing. – iLikeDirt Feb 23 '15 at 15:17
  • I would not get a heat pump if you live in cold areas. I have never had a heat pump work properly to heat a space. Heat pumps are designed for auxiliary heat or to heat places that have very mild winters. Most units don't allow for low ambient operation which means they will not operate under 32 degrees. Also the low ambient heat pump systems have a very poor btu output when the outdoor temperature is below 32 degrees. Most systems will give less that half the btu output when below 32 degrees, and the system will constantly be going into defrost. – Mnc123 Feb 23 '15 at 16:18
  • Why not get a combi boiler/tankless that feeds an air handler to give you heat as well as domestic hot water. If you do not have gas or propane however this would not be possible. – Mnc123 Feb 23 '15 at 16:22
    We definitely live in a cold climate. We are in central Ohio and this weinter we hit -20 with a wind chill of -40. Can you provide any evidence that a geothermal system will not pay for itself? We can get it installed cheaper that usualy (around $7k) because we can use our well as the supply instead of a closed loop system. Also we can get a 20% tax credit for the system. – BWDesign Mar 03 '15 at 15:53
Concrete is not an insulator. It is thermal mass; virtually the opposite thing. You absolutely need to insulate your slab on all sides that you don't want heat escaping (i.e. all but the top).
If you can't put insulation under the new radiant hydronic slab, you should abandon it. 50% of the heat will he lost under the house. It will run all the time and cost you a ton of money.
Radiant slabs are often abandoned in my experience. They often don't work right, and this is a surefire way to torpedo the project.
iLikeDirt
  • 12,543
  • 52
Heat moves from hot to cold. The more insulation you put in walls, roof lines, or attics, the more heat you push into the uninsulated ground. It makes sense to insulate and isolate the ground from your inside environment even if it doesn't have floor heating.
Never install radiant without insulation, the insulation is more important than the radiant heating system.
Doresoom
  • 15,623
  • 80
  • 118
  • That is an interesting point. You would recommend installing insulation under the slab even when not using radiant heat? – BWDesign Apr 25 '15 at 00:52
