I'm looking to build a retaining wall on my sloped backyard. I'll be using cinder blocks (with mortar to join them together and rebar for added stability).
(added info: at the lowest point the wall is going to be close to 4 feet tall, not counting how deep I have to dig and how much of the wall needs to be underground)
Some questions:
1) Footing or no footing? Can I start setting the cinder blocks directly on base gravel, with rebar vertically every 3-4 feet for added stability, and filling them up with mortar as I go? Or do I need footing?
2) If I need a footing, how deep into the ground should my footing be? Not how deep the footing itself should be (I'm thinking I'll go with a 1' footing—feel free to comment on that), but rather how deep into the ground do I need to dig my trench in order to set the footing?
I know that for gravity walls on sloped yards I need to measure 5' out of where I plan my wall to be and dig the difference. What about for cinder block walls, is it the same? Or the added strength and stability of rebar+mortar, or footing+rebar+mortar, makes it so I don't have to dig as much?
Hope the info I provided is sufficient to get help and answers from. Let me know if you need me to try and sketch the design of the wall for added context.
Thanks
Jack
  • 34,187
  • 60
ttothec
  • 191
  • I'd suggest looking into a pinned Keystone or Allen block wall instead. You can find all kinds of great info by Googling it. (I'm posting a year late, so if you have the project done maybe you can post an update!) –  Jun 24 '16 at 22:38
Can I convince you to not do this ?
Honestly not trying to be an ass.
Please, please - Get a quote from a company that builds retaining walls.
The quote will cost very little or nothing.
You will be shocked at the cost, and not in a good way.
The quantity of material needed to build the wall, will amaze you.
Please get a quote or two first.
I promise you, you will not regret it.
Block walls work in compression, heavy things directly on top of them is fine.
Side to side, their goal in life is to tip over, and they are damn good at it.
Blocks work because they are tied to very solid, heavy things at the top and bottom that run the length of the wall, and have regular supports at a right angle to the length of the brick.
A 1' deep pile of soil, behind a 4' block wall, 1 block long, weighs 500 pounds.
The path of least resistance is to knock over the wall.
Blocks, attached with mortar, to the soil behind the wall about as strong as a 2x10 resting on its edge.
The question is more one of how many yards of concrete will you need to build the footing.
Some Guy
  • 2,247
  • Thanks for the comment. I did get quite a few quotes. They ranged anywhere from $4,000 to $7,000. I figured that if I built it myself I'd save a considerable amount of money. With a CMU mortared wall I'm looking at something in the $2,000 range in materials (cinder blocks, cement for footing, mortar, rebar, drain, drain rock, etc)... The footing will be 60 feet in length, 2 feet in width and 1 foot in depth. My question still stands tho: since I'm building this on a slope, how deep do I have to dig to set the footing? – ttothec Mar 20 '15 at 20:19
  • Frost line at 18", add 2 or 3 inches so you know you are past it, 2 or 3 for some drainage, and 2 or 3 more because you are going to want some working space to get things really level across 60 feet. Dig for a target of 28 inches and don't panic if you only get down to 24 inches in some places. – Some Guy Mar 20 '15 at 21:53
    That 500 pounds of soil is not pushing laterally on the wall with 500 pounds of force. – Craig Tullis May 23 '17 at 15:11
To make a retaining wall the stone (or other immutable material) must be make a 45-degree angle into the hillside.
The footing must be as broad as the plinth and must go as deep as the frost line. In New England where I live the frost line is 4 feet deep, so I have used that depth in the diagram.
Any other form of wall will eventually collapse. If the wall depends on metal in any way then it will collapse when the metal rusts. If the wall depends on mortar, then it will collapse when the mortar erodes. If an angle less than 45-degrees is used or if a non-fixed material, like gravel, is used as fill, then the wall will bulge out over time and eventually collapse.
The Roman walls still standing on the Appian Way and in other places that have lasted for 2000 years are all of the design I have shown.
retaining wall
Tyler Durden
  • 6,789
  • 49
  • 98
  • Thanks Tyler. The frost line in Hayward, CA (where I want to build the wall at) is between 12 and 18 inches. If I add gravel to the back of my wall, do I still need the 45 degree angle? I guess my question related specifically at walls built with cinder blocks and whether or not I need a footing. It seems like I do need a footing. So my question now is, how deep do I need to build my footing? Below or at the frost line? Also, in your diagram, imagine a continuation of the slope on the left side.. that's what I have. I'm building my wall on a slope.. does that change the depth of the footing? – ttothec Mar 16 '15 at 23:38
    If the frost line is 18 inches you only need to go 18 inches deep. Every part of the wall must be at least 18 inches deep. The only caveat is that you have to take into account water. Putting gravel in can be useful for diverting water. The wall has to be at 45-degrees the gravel does not count. Gravel does not count for the depth either. If you put gravel below the wall, the wall itself still has to be at least 18 inches deep. – Tyler Durden Mar 16 '15 at 23:46
  • Speaking as a structural engineer, the wall does not *have* to have a 45 degree back slope. It'll give you a nice robust wall, sure, but there are other ways to build a wall. Rebar is one of them. – AndyT May 23 '17 at 14:58
  • @AndyT As it says right in my answer, a retaining wall held by rebar will fail as soon as the rebar rusts. In the 1990s I had to commute through an incredibly slow construction point for 10 years because jerkoff engineers built a retaining wall back in the 1950s with rebar and it had failed. About 2-3 miles of the Massachusetts Turnpike are going to have to get a massive construction pain in the ass for the same reason soon. Have fun driving through that. Yeah, just keep using rebar and keep rebuilding every 50 years, idiot. – Tyler Durden Nov 30 '20 at 13:38
  • @AndyT You know the Princeton stadium had to COMPLETELY rebuilt because it used a rebar construction. In the 1920s it was built at enormous expense to hold 70,000 people and then in the 1990s, the entire stadium had to be demolished and rebuilt at enormous expense because all the rebar had rusted. Morons. – Tyler Durden Nov 30 '20 at 13:39
  • @TylerDurden - If you're designing to last forever, then sure. But no engineer ever designed anything to last forever, because no client wants to pay for something that will last forever when they can have something that'll last for 120 years for much cheaper. And even your design won't necessarily survive, say, an earthquake. – AndyT Nov 30 '20 at 14:34
A footing would be nice; if you do one with solid concrete, I'd leave some channels through for drainage. Another options is to use road base; the different sizes of rock lock together very tightly. Make sure that any loose base is well-compacted.
Note that in many places any wall higher than 3' requires a permit and/or engineering.
Eric Gunnerson
  • 2,909
I landscape in MN where the frost table is much greater. We bury the base course of our retaining walls which is generally 6"-7" with at least 4" of Class 5 gravel underneath. Any wall greater than 4' needs a permit in general. The one thing that nobody has taken into account is the need for water drainage. Compact class 5 on the backside of your baseblock and install a perforated drain tile that drains at the lowest point of the wall or put outlets on the first unburied course generally one every 50'. in your case i would have put in two 10' in from the outside of the walls. Put permeable (allows water to pass through) fabric underneath the drain tile and up the back side of the wall.
Back fill with round rock of any sort a foot behind the wall and all the way to the top of the wall; allowing 6 inches for black dirt if you want grass to grow. Anything behind that 1' of round drain rock can be the fill that was taken out during initial excavation. All of this back fill should be compacted to avoid settling and also washing of the fill into the drain rock. Put 1/16" lean on your base course per layer of block. So your 4' wall should have about a half inch of lean to it. An easier way to achieve this is the bubble on your level should be split in half by the line facing the front of your wall. Apply this to any wall and as long your building material, whether it be block or concrete and mortar, stays intact your wall should not push forward due to proper drainage, proper lean, and proper compaction of base and back fill.
ThreePhaseEel
  • 81,744
  • 227
Building code states that a footing supporting a structure above must be 8” below the local established frost line depth.
Nader
