116
Looks like WD-40 can be used for lubricating just about any metal parts.
Are there non-obvious cases where using WD-40 will be harmful to the stuff lubricated?
Aarthi
  • 1,143
sharptooth
  • 9,537
  • 62
  • 87
  • 60
    Don't combine WD-40 and Duct Tape, you risk creating a black hole. – Adam Prax May 10 '11 at 16:00
    A lighter seems to be a bad idea to "lubricate". – Spechal May 11 '11 at 04:46
  • 39
    Also, it's not for ... *personal* use. – Jay Bazuzi Mar 11 '12 at 01:10
    By the answers given, it's clear that you asked the exact opposite question of the one you should have asked, to wit: "When should I use WD-40?" So far, we've learned that it's not a lubricant, it will attack plastic, lacquer (insulation on magnet wire in a motor), etc. It's really just for cleaning water off of things, and happens to work as a weak penetrating lubricant. It's kind of like a Swiss Army Knife in that you could use it for all sorts of things, but you really shouldn't. Use the proper lubricant for the job and you'll be happier in the long run. – Andrew Beals Mar 12 '12 at 19:09
    Perhaps this will help: http://i.stack.imgur.com/EzXXb.jpg – oscilatingcretin Mar 14 '12 at 18:13
  • WD-40 is great for cleaning Stainless Steel as well. Apply lightly and buff off. – Dutchie432 Mar 20 '12 at 15:21
    **EVERYBODY IT'S ON LIFEHACKER!!!** [(Article)](http://lifehacker.com/5891936/when-should-i-not-use-wd+40?comment=49886294) Sorry. Got a little over excited there. But still, it's pretty cool. However, someone insulted us in the comments as a "Wikipedia like site." :( Actually, Wikipedia has been proved more reliable than other sources because that everything is monitored so much and updated so frequently, plus all info needs a source, and you can easily view that source. – Anonymous Penguin Oct 25 '13 at 01:26
  • @AnnonomusPerson: Well, the major objection against Wikipedia I've heard is "anyone can post any bulls*t" there - and that's where the argument just ends for that idea proponents - they don't care there's history and they don't care there're reverts. Since anyone can post any bulls*t here technically this site is indeed like Wikipedia. – sharptooth Oct 25 '13 at 07:07
  • @sharptooth Yeah... **BUT... they both have edit queues. Here they have to be approved by a higher user.** Someone with that high rep usually knows a lot about that field and can look something up. Here, it's actually better than Wikipedia because if it works, it works. There is the occasional one about *how* something works or more scientific background, such as this one, but then a lot of times it is based from experience. And also most questions have a fair amount of experts "patrolling" (free time!) some questions. They often comment. And there's lots of traffic: I've gotten 25,000 hits. – Anonymous Penguin Oct 25 '13 at 21:06
  • @AnnonomusPerson: Well, that would convince me, but not them - they will focus on *anyone can post any bulls*t* part and ignore anything else. – sharptooth Oct 28 '13 at 06:14
  • Intuitively, putting WD-40 on pancakes might make it seem like you could consume more pancakes without having to take a drink of water. However, WD-40 is toxic and should not be used for this purpose or lubrication of any other food-related products. This is the type of response a negative question solicits. – statueuphemism Feb 14 '18 at 02:26
  • You should not use WD-40 when you want to lubricate something, you should use a lubricant. ( it will evaporate away and leave you with nothing but a need for a lubricant. ) You should use it when you want a penetrant to get in and loosen old dried up lubricant or to free a rusty nut or as a temporary "fix". – Alaska Man Dec 23 '19 at 21:40
17 Answers17
69
  1. Firearms - you should never use WD-40 to clean or maintain firearms.
  2. Drive chains of any type - because WD-40 isn't a lubricant it really will not work well on Drive chains of any type.
  3. Gears of any type - WD-40 doesn't have enough lubrication effect to be useful on any type of gearing. Only specified gear lubricants should be used.
  4. Locks - Use powdered graphite or silicon spray instead.
nevadaexile
  • 714
    WD-40 is a lubricant. – xpda Mar 17 '12 at 15:15
    No it's not, really. See other answers. – tomfanning Mar 18 '12 at 21:51
    @tomfanning "WD-40 cleans/degreases, penetrates to loosen up stuck parts, prevents corrosion and is a light lubricant." http://www.wd40.com/faqs/ There are several more mentions of WD-40 being a lubricant on the site. It contains mineral oil, which is a light lubricant. – xpda Mar 19 '12 at 04:08
    I've seen locksmiths use WD-40 in locks. (I can't vouch for their being *good* locksmiths though. The one that changed my ignition didn't rekey it to match my keys.) – aij Sep 13 '14 at 20:57
  • What about for sliding doors? (like one that goes outside to a porch). namely the bottom part that collects dirt/gets squeaky. – msmith1114 Feb 14 '18 at 05:14
    @xpda, I can't COUNT the number of times I've had people spout out the nonsense of **_"WD-40 isn't a lubricant! It's a Water Displacer!"_** Go to any hardware store, and just about every clerk seems chomping at the bit, ready to "teach" people this. When it happens, I direct them to the website faqs, like you did. It's really a bit of craziness. A little like a reverse wives tale perhaps, except that they want to jump over the isles to tell you about it. – tgm1024--Monica was mistreated Jul 31 '19 at 01:03
50
WD-40 does a lot of things, unfortunately this means that it does not do any one thing well.
As a lubricant WD-40 is very thin and runny. WD-40 will lubricate for a short time, but will quickly run off. This is a side effect from it being a penetrant. If it was thicker for better lubrication it would not penetrate well.
WD-40 is a GREAT quick-fix and one-can option. I use it in that role, it gets things going long enough to let me finish the current task and get back to the shop. Once there I can get to my real penetrants (Kroil, PB Blaster) and my real lubricants (oil, white lithium) and repair the problem.
Bonus tip: wrap your WD-40 can with several turns of duct-tape. You now have two of the best quick-fix wonders in one package.
Freiheit
  • 4,162
  • 47
  • 67
    And WD-40 is really good at cleaning away whatever little you may have left of a previously applied thicker lubricant. – Vebjorn Ljosa May 10 '11 at 23:17
28
Never use WD 40 on door hinges or anything you want to keep clean. It attracts dirt and dust. It will turn your hinge pins black.
shirlock homes
  • 58,152
  • 84
  • 166
    What would be good for door hinges? – Paul D. Waite Jun 01 '11 at 14:33
    This is also the reason you do not ever use it in locks, especially pin tumblers. My brother (a locksmith) used to swear at people who tried to "clean" a tumbler with WD-40. And he's not a sweary person. – staticsan Mar 09 '12 at 02:11
    @PaulD.Waite A very light oil is good for hinges. a common brand is called 3-in-1 Oil. While not as easy to apply, vegetable oil (the kind used for cooking) will work and you can even get it in a spray can (brand name Pam) but don't get the kind with flour or flavoring. – Chris E Mar 09 '12 at 22:35
    3-in-1 oil will attract dirt and dust just as bad as WD-40. And for matter, so will any other type of oil or grease. For locks you can use graphite powder, for door hinges the natural polishing action of using them is enough. – Jonathan Allen Mar 17 '12 at 07:10
    "for door hinges the natural polishing action of using them is enough." Oh yeah? Tell that to my door hinges. I open and close the door several times a day, yet somehow it continues to make a loud creaking noise every time. If not WD-40, what sort of product would you suggest to quiet creaky door hinges? (And if you're worried about WD-40 turning your hinge pins black, then graphite powder doesn't seem like a useful alternative... :) – Josh Jun 09 '18 at 20:43
  • I'm sorry, but this is nonsense. ANY oil will turn black on a metal-on-metal wear-point. Motor oil turns black, as does 3-in-1, WD-40 and **_EVEN WHITE LITHIUM GREASE_**. C'mon man. – tgm1024--Monica was mistreated Jul 31 '19 at 01:09
  • @Josh Use PTFE Lube a.k.a dry lube – Travis Su Jan 10 '20 at 02:14
25
It doesn't move and it should = WD-40
If it does move and it shouldn't = duct tape
WD-40 is only used as an immediate lubricant, e.g. for a stuck bolt, or as water dispersant. Don't use it where you need longer term lubrication, like a bike chain.
End Anti-Semitic Hate
  • 2,193
  • 56
mgb
  • 1,615
Rubik's cubes. Serious cubers will lube their cubes with Jigaloo, CRC silicone, or even vaseline. But, will point and laugh at noobs who use WD-40, as it melts the cube, likely seizing it. Yet people keep doing it.
cidermonkey
  • 331
Bicycle chains!
WD40 will ruin a bike chain and the gears wear out quicker. It washes the dirt in, the dirt acts as an abrasive and not a lubricant.
Mathew
  • 289
  • Try grease or heavy gear oil, that will really attract dirt. I like WD-40 or 3-in-1 oil for my bike specially because it doesn't last. – Jonathan Allen Mar 17 '12 at 07:12
    WD-40 will not ruin a bike chain. It will loosen up a rusty chain. Rust and dirt will ruin a bike chain. However, wax or teflon lubricants will keep a bike chain cleaner (and you can go faster). – xpda Mar 17 '12 at 15:18
    @JonathanAllen: Some say that you should never oil a dirty chain: you should either not oil it at all, or you should clean it well before oiling it. Others disagree. See [here](http://sheldonbrown.com/chains.html#oil). See also [this question](https://bicycles.stackexchange.com/questions/51641/if-your-chain-is-clean-and-working-well-is-it-truly-necessary-to-ever-lubricate), which discusses whether or not the simplest strategy is advisable. – unforgettableidSupportsMonica Jan 03 '18 at 08:35
18
Musical Instruments.
My sister works at a music store, and a father ruined an $800 clarinet by using WD-40 on "the squeaky part".
AnonJr
  • 289
Lock cylinders. Never in lock cylinders. Doorknobs, padlocks, etc. - the residue left will just attract dirt & grit, and prematurely wear down the works.
This was given me by a college friend whose dad worked on the maintenance staff - so they did a lot of locks!! It probably took years to see the pattern, but any lock they had shot with WD-40 eventually failed before un-WD'ed locks.
Chuk
  • 151
Personal experience: An electrician told me never to squirt WD40 into an electric motor (bathroom exhaust fan) as it can be ignited.
robin56
  • 141
    Duh, so will any oil. – Jonathan Allen Mar 17 '12 at 07:14
    Light oils will. Motor oil won't. But it's hard to get motor oil up there. – xpda Mar 17 '12 at 15:20
    In the old days it was much more flammable, I used to Cary a can in my jeep , a good heavy shot inside a tire that was knocked off the rim and a lighter would reseat the tire so it could be filled up with a hand pump. They changed the formula or propellant and the new stuff is not as flammable. – Ed Beal Nov 27 '17 at 14:11
13
It never should be used on AirSoft or PaintBall weapons as it melts the seals.
Steven
  • 27,594
  • 53
  • 88
Francisco
  • 131
I read an article once by a clock repairman who described how bad WD-40 is for precision clockworks. The main reason has been given already: it attracts dirt, which acts as an abrasive and eventually gums up the action.
Old_Dragoon
  • 111
For something where you need longer lasting lubrication, consider Silicone-based spray. Comes in a can just like WD-40, but it "sticks" better.
myron-semack
  • 3,443
  • 25
WD-40 is for displacing water, hence the initials.
It's not made for anything else. The rest is marketing spit and sparkle. Seriously if that same marketing team had worked for Jiffy peanut butter, there'd be a can of that on your toolbox instead of WD-40.
In every category in which people use WD-40, there are better products. Think of it as the "Harbor Freight universal thing that comes in spray cans" and set your expectations accordingly.
It is also notorious for wrecking plastic or rubber. I used to spray it on printer ribbons to extend their life, what I got out of the deal was a delaminated printhead, a $150 part.
If you think I'm being cynical, my local gas station has WD-40 for $6.50 a can, and Liquid Wrench for $4.50 a can. There's no reason for that but brand power.
Edit: I wasn't quite right. Actually WD-40 was designed for polishing your missile.
Seriously. It was made to rub/spray on the aluminum skin of the SM-65 Atlas missile to prevent corrosion. There actually were 40 attempts at the right formula for that purpose. None of which gave the slightest consideration for use as a penetrating oil.
It attacks polycarbonate windows such as Tufak or Lexan too. Shooting through a bullet proof window after applying is NOT recommended.
RichardS
For the same reason you wouldn't use it on door hinges, it should never be used for chair and sofa mechanisms. Because WD-40 attracts dust and turns things black, over time that dirt accumulation within the moving parts will build up and eventually start to fall off onto carpeting creating a terrible black mess that is nearly impossible to remove.
Tim
Don't ever use WD-40 on something that has already been lubricated (like with white lithium grease, etc). The WD-40 will break down the grease and make a real mess.
Steven
  • 27,594
  • 53
  • 88
john
Any electric motor, even if the rotor is stuck from filthy dried-up lubricant! Think squeaky furnace blower motors, fans that won't start up, lawn mower engines, etc.
The solvent not only removes any remaining lube, but it can melt coil wires (the lightly-coated copper wires twisted up in electric motors) and cause an electrical short. New fan motor! $200!
I did use it to help start a snowblower, which worked well for 1 use, then never ran again (likely due to WD-40's hygroscopic nature). There ARE, apparently, OTHER WD-#'s
drew
  • 37
    I use wd40 on motors with oillite bearings all the time no wire failures or damage to the varnish on the wires, when grease breaks down wd40 is a great way to get things moving then adding a proper oil or grease. – Ed Beal Nov 27 '17 at 14:15
