I've a Type C electric socket that not holds solidly in a wall slot.
It uses metallic lateral ears and a pair of screws which controls their angle to hold itself into a wall socket.
Wall socket is concrete.
Is there any way to fix it solidly into this wall socket?
PaulD
  • 131
    A photo or two would be a tremendous help toward getting folks up to speed on your problem. – Michael Karas Mar 28 '15 at 11:20
  • Use [spacers](http://diy.stackexchange.com/questions/28290/how-do-i-extend-outlets-after-installing-a-backsplash/28317#28317). – Mazura Jul 27 '15 at 02:22
You can use a 90 degree, type C plug
And then fasten to the wall, with a couple of cable clamps
A clamp close to the outlet and it will be difficult to remove, and clamps down or along the wall will keep it safe.
Hope this helps
Michael Karas
  • 64,093
  • 63
  • 142
Some Guy
  • 2,247
