Is there a rule of thumb for how often a circular saw blade should be replaced? Is visually inspecting the blade condition enough?
4when it gets dull = when it starts binding/tearing/chipping/burning/just a pain to use. – DA01 May 20 '11 at 15:36
@DA01: Can you add that as an answer? – Doresoom May 20 '11 at 16:19
sure! Will make it an answer... – DA01 May 20 '11 at 17:14
If you are thinking about replacing the blade, it's probably time to replace the blade. At worst, it doesn't help and the blade you removed becomes your spare, or you swap back. That's assuming you aren't abusing the tool, of course. – keshlam Mar 24 '15 at 22:13
You should replace your blade when its dull. Ways to tell its dull:
- it starts binding
- it tears/chips the substance more than usual
- it burns the wood
- just a pain to use = a sharp blade should let you push the saw forward with minimum effort. If you find yourself forcing the saw forward (not ideal from a safety perspective), change the blade.
- 24,235
- 27
- 76
- 146
How many carbide teeth can be missing on a 40T blade before you change it out? I typically find this to be the main reason the blades are not cutting well. – Fresh Codemonger Nov 26 '20 at 08:54
Looks for worn or chipped carbide teeth. If the teeth are merely coated in pitch, you can remove it with oven cleaner (or in a pinch windex), and old tooth brush, and some elbow grease.
Blades should be replaced when they get dull or after you hit a screw or a hard knot.Cleaning saw blades
- 1,321
- 9
- 8
1Obviously baking the blades would ruin the temper and edge, but is it safe to soak the blades in cold application oven cleaner? – Justin Dearing May 20 '11 at 17:56
That's all I normally use. You don't have to use much, just let it soak for about 5 min and scrub it with the toothbrush (wear safety goggles!) and rinse thoroughly with water. – electricsauce May 20 '11 at 20:15
2Edited my post above. The article on newwoodworker.com says that oven cleaner can attack the binder that holds the carbide to the blade. The article recommends simple green or a store bought cleaning solution. I've cleaned my blades for years with oven cleaner with no negative effects, but I think I'm going to try simple green next time. – electricsauce May 20 '11 at 20:22
1It's all fun and games until the carbide teeth on your saw blade start flying off, huh? – Craig Tullis Jan 19 '15 at 05:50
There is a fantastic way to clean pitch off of saw blades. It is something that everyone has at home. Laundry detergent. Yeah, that's right simple laundry detergent! I put a heavily burnt/pitch covered blade in a 12"x12"x5" plastic tub with a gallon of hot water and quarter cup laundry detergent. Let it soak for three hours. Use a nylon brush/toothbrush, and be amazed. The pitch comes off like soot. Rinse off. Dry the blade thoroughly (I used a heat gun). Apply thin Coat of oil, or blade oil on carbide tips.
- 1
Sometimes you're using a sharp blade and it still cuts poorly. You might be ripping with a crosscutting blade or crosscutting with a ripping blade. Just like you do with your fish hooks, run the back of a finger nail over the saw teeth: if it scrapes, the teeth are sharp; if it slips over your nail without scraping, it's not sharp.
- 1
